Hello everyone, I'm trying to build a new PC for myself and would like to build an all white PC build. I have seen many youtube tutorial video and I came up with my own list of items which I would like to use for the build but I'm not sure if they are all fully compatible. Do help me out :D
Case - NZXT S340 Elite (White)
Motherboard - Asus Prime Z270-A
CPU - Intel I7-7700K
GPU - Asus Dual Series Geforce GTX 1070 OC edition 8GB GDDR5
Storage - western digital 2TB HDD and Samsung 850 EVO SSD (500GB)
Ram -Corsair Vengeance LPX3000MHz CL15(White)
Cooler - Deepcool Gamer storm captain 240EX white
Power supply - Fractal Design Newton R3 600W
I will be using this PC for photo and video editing as well as some light gaming like CSGO and Dota2. Do help me point out if i miss or overkill or under buy some parts. Thank you guys so much
https://linustechtips.com/topic/767716-white-pc-build/
Well for CSGO and DOTA2 1070 is super overkill.
I am not sure about the psu quality either.
As for the AIO it will be compatible but people reporting about captain leaking/bursting water so i'ill find another AIO or just use Cryorig h7 it has a black plate and white fans..
For the psu get one from tier 3 above on this list.
Behold the power of Chuck Norris the forbidden one.
https://linustechtips.com/topic/767716-white-pc-build/#findComment-9693352
Then go with Ryzen 7 1700 with B350 or X370(only for sli and more lanes) as for those games Ryzen should be more than enough(7700k is better in gaming but for light gaming especially those games not a big difference even if it is then only small diff). But a huge diff in photo and video editing.
https://linustechtips.com/topic/767716-white-pc-build/#findComment-9693370
What apps do you use for photo and video editing and how often do you use them? Ryzen may or may not be worth it for you.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/767716-white-pc-build/#findComment-9693458
The S340 Elite has a psu shroud so you can use any psu without interfering with the color scheme. Consider getting a better psu.
A budget and pcpartpicker permalink to the build would help.
https://linustechtips.com/topic/767716-white-pc-build/#findComment-9693522
I am also considering a black and white build and thinking of playing 1080p60fps on ultra on all games + doing some work like running several VMs etc.
I see your budget may be higher, but you might take a look at what I'm planning at the moment here: https://pcpartpicker.com/user/Verrm/saved/7F9LkL
If you are planning to play on 1080p monitor then I think that a 7700k+gf 1070 is unnecessarily too much. With my build I think you'll also achieve solid frames and good future proofing but for less $$. And you'll get a better PC for your photo and video editing.
Edit: I am also afraid of this AIO a bit, I think I'll get an air cooler.
https://linustechtips.com/topic/767716-white-pc-build/#findComment-9703418
Please explain what you really mean about benefits or demerits of amd cpu with software????
CZ I am also going to build one like it at this budget and will do the same thing. And I was thinking of Ryzen 7 1700
https://linustechtips.com/topic/767716-white-pc-build/#findComment-9704990
Some apps like photoshop are more single threaded, and so a 7700k would be more worth it for those. However, in multi threaded apps like premier or sony vegas, ryzen would be better.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/767716-white-pc-build/#findComment-9705287
