6 minutes ago, skkler said:
is there anyone or anywhere I can get some 7 pin sata to usb connectors??
Why not USB2 header to USB2?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/767592-cable-mod/#findComment-9692325
because its for a project, plan is to put some harddrives in a enclose and use a sata data to usb to connect the harddrive to a usb hub then plug the hub into a raspberry pi to make external (non NAS) storage drive
https://linustechtips.com/topic/767592-cable-mod/#findComment-9692333
Get a normal enclosure then. Even this one would work:
https://www.amazon.com/ORICO-USB3-0-External-Enclosure-Supported/dp/B01M08LCXW/ref=sr_1_5?ie=UTF8&qid=1492405318&sr=8-5&keywords=2.5+enclosure
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/767592-cable-mod/#findComment-9692338
Just now, JDE said:
them aren't big enough. plus they are pricey
https://linustechtips.com/topic/767592-cable-mod/#findComment-9692340
https://www.amazon.com/StarTech-SATA-Drive-Adapter-Cable/dp/B00HJZJI84/ref=sr_1_3?ie=UTF8&qid=1492405465&sr=8-3&keywords=sata+to+usb+cable
Fits 2.5" drives only because of power usage
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/767592-cable-mod/#findComment-9692344
