1 minute ago, lightlazer said:
I just built my tower I have a Asus x370 pro in it when I boot up it sends me right to bios some one help I wanna play games and I wanna sleep.
did you install an OS?
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/767145-help-%3F/#findComment-9687530
I got it to work windows loaded but I can't use my mouse of keyboard help
turn on "always on USB" in your BIOS, and try the ole' replug after windows is booted. if you're using wireless stuff, try to find a wired one just for test purposes.
https://linustechtips.com/topic/767145-help-%3F/#findComment-9687614
Every USB is on and the legacy port is not working too I always use wired and led key board and mouse
https://linustechtips.com/topic/767145-help-%3F/#findComment-9687644
5 minutes ago, crzyces said:
Try starting in safe mode, go to last known good configuration. Hopefully that will let you type in your password.
I got in through PS2 all I have is a key board what do I start searching for my internet is not connecting and I can't slectthe any windows updates
https://linustechtips.com/topic/767145-help-%3F/#findComment-9687730
You can use the tab key to navigate through options.
There is enough youth in this world, how about a fountain of smart?
https://linustechtips.com/topic/767145-help-%3F/#findComment-9687734
