My friend has MSI Z77 MPOWER motherboard, i7 3770 (non k) & he just got these RAMs: Kingston HyperX Beast 8 GB Kit (2x4 GB) 2400MHz, but problem is, he can't make them work on 2400mhz. They work only on 2133mhz. Any thoughts what is the problem? Why they don't work on that speed?
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/76661-2400mhz-ram-problem/
He need to raise the voltage to 1.65v
Also, why does he have a non-K i7 on a Z77 board?
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052028
enter all the settings manually: clock, latencies, command rate, voltage
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052035
Could you explain exactly which settings to use? like what timings & voltages?
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052043
Try 11-12-12-31 at 1.65v
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052048
When he sets profile 1. timings & voltage sets automatically & speed sets to 2400mhz, but after this PC keeps restarting continuously.
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052054
for that kit its 2400 mhz, 11-13-13, command rate 1, 1.65V
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052057
Thx, will tell him now.
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052058
That means that the setting aren't going to work so he need to increase the voltage further, maybe 11-12-12-31 at 1.675v
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052061
also, try updating the bios
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052063
gonne end up frying the ram. obviously they dont know what they are doing.
Tell him to be carefull!
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052065
Ask him to set an XMP profile as Kingston usually advertizes their speed in XMP. The manual should say how to set up XMP. Refer to 2-13.
Edited by mgsstar
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052068
Thx, will try this too.
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052069
If there's a sticker on the side of the RAM, it should have all of the tested latencies, timings, voltage and frequency (my Corsair ones do) so I can take a picture of them and manually dial in all of the necessary stuff, though the X.M.P profile should fix all of that up for you.
Is XMP enabled?
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052084
Is XMP enabled?
Yes, he enabled it
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052093
I think maybe cpu is limiting it? As it's not k version?
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052100
Possibly, though chances are it's the motherboard/BIOS settings.
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052119
one more question: Now he has such settings: 2133mhz, 11-12-12-31 at 1.675v & if he leaves those settings, will it be okay?
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052130
dang.. I was planning to buy that same Memory stick next week.
Oh well, I guess I'll just stick to Crucial Memory sticks -_-
CPU: Intel Core i5-4670k Mobo: MSI Z97 Gaming 3 RAM: Crucial Ballistix Tactical Tracer 8GB 1866 Video Card: MSI GTX 970 GAMING 4G SSDSamsung 840 Evo 250GB HDD: WD 1TB + 500GB Caviar Blue
PSU: EVGA SuperNOVA 750W G2 Case: Gigabyte GZ-G1 Mouse: Corsair M65 RGB Keyboard: Corsair K70 MX Brown MousePad: Corsair MM200
Steam/Origin/Uplay: renz62
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052246
We don't know. Maybe it's because of his non k cpu...
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052248
No, no. This ram is clearly crap. Look at this one person who is having trouble out of the 1000's of people who use this ram with no problems.
Finally my Santa hat doesn't look out of place
https://linustechtips.com/topic/76661-2400mhz-ram-problem/#findComment-1052338
