Pin connectors... Help
Solved by Jito463,
Just now, kennakenna said:when you say outside is positive and inside is negative does. That mean they go in horizontally?
Correct. Just look at the diagram below the pins.
voltigeurramon ·
Posted in Troubleshooting0 -
Vibora ·
Posted in New Builds and Planning4 -
4
3
Doctah ·
Posted in Peripherals3 -
6
michaelb198 ·
Posted in Peripherals2 -
errorcode123_dindin1 ·
Posted in Graphics Cards5
