How Can i see my cpu temps i have a ryzen 5 1600
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/765667-cpu-temps/
13 hours ago, Aidanlockett1 said:
http://openhardwaremonitor.org/
its gooid and free i use it and i have an i5 6600 i think they released ryzen 5 support
it docent show temps
Peripherals
https://linustechtips.com/topic/765667-cpu-temps/#findComment-9670620
yes it does
Idk for me its not
Peripherals
https://linustechtips.com/topic/765667-cpu-temps/#findComment-9670646
Use Ryzen Master
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/765667-cpu-temps/#findComment-9670705
13 hours ago, knightslugger said:
Use Ryzen Master
Ya i got it but its at 39 c is that normal or
Peripherals
https://linustechtips.com/topic/765667-cpu-temps/#findComment-9670714
perfectly. what is it under load, and what cooler? Spire?
System specs:
https://linustechtips.com/topic/765667-cpu-temps/#findComment-9670716
Just have browser open cpu is at 4% and spire
Peripherals
https://linustechtips.com/topic/765667-cpu-temps/#findComment-9670759
They run a little warm at idle, 40 ain't bad, i assume it's air cooled. Full load is where you want to check for excessive temps. I recommend realbench as a stress testing utility.
System specs:
https://linustechtips.com/topic/765667-cpu-temps/#findComment-9670828
