is using a custom resolution on a display bad?
Solved by Glenwing,
4 minutes ago, AluminiumTech said:So,
GeForce experience
Ngreediahas recommended that I run at 2517x1527 at some games by downsampling.
And I was wondering if there was any damage that could be caused to my monitor by running it at 2715x1527 custom resolution instead of it's normal 1920x1080.
I know it doesn't replicate the look or feel of 1440p or thereabouts but I wanted some extra screen real estate until I get a monitor upgrade.
Can any damage come to my monitor or am I fine?
No, the monitor never receives the higher resolution image, it's downscaled to 1080p before it leaves the graphics card. The monitor won't even know the difference.
