Not that I can think of.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/76522-will-there-be-issues/#findComment-1049977
why even ask if the site says it wont work...
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/76522-will-there-be-issues/#findComment-1050040
i agree if the site say's it wouldn't why ask again?
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
https://linustechtips.com/topic/76522-will-there-be-issues/#findComment-1050059
Just turn rotate the cooler, the temps will be the same.
thanks. will i be able to install memory with high heatsinks?
Probably not, you'll have to check the clearance under the cooler and how tall the ram is.
Have you considered something like the Shadow rock 2?
Error: 410
https://linustechtips.com/topic/76522-will-there-be-issues/#findComment-1050089
Yes, because it's a slim heatsink.
CPU: Intel Core 2 Duo E7300 Motherboard: Asus P5KPL-AM (mATX) RAM : 3GB GPU : Asus Radeon HD 4670 Case : Generic mATX Case Storage: Crucial M500 240 GB & WD Blue 500GB PSU: 420W
https://linustechtips.com/topic/76522-will-there-be-issues/#findComment-1050221
The front fan may block the first ram slot so if you are planning to use the first ram slot, keep it below 32mm.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/76522-will-there-be-issues/#findComment-1051247
