Usually channel 3 or 4.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/765104-n64-problems/#findComment-9664448
6 minutes ago, MonsterHunter280 said:
What do you mean?
On the TV, switch to channel 3 or 4.
https://linustechtips.com/topic/765104-n64-problems/#findComment-9664580
Just now, MonsterHunter280 said:
Ain't there. What now?
Are you sure that aerial cable and N64 work?
https://linustechtips.com/topic/765104-n64-problems/#findComment-9664588
https://linustechtips.com/topic/765104-n64-problems/#findComment-9664598
I suspect that this isn't a US setup and that the TV needs to be tuned into the frequency being transmitted by the N64.
If this is a modern TV then you've have to switch the source to analogue and go into the tuning or channel section of the menu system and select to either do a manual or automatic tuning (manual allows you to scan through each frequency until you fins the correct signal, and automatic will do it for you saving each found signal as it goes).
If you didn't do so already, you should make sure you was checking the analogue channel section and not the digital channel section as these should be separate.
You should also consider getting a scart cable as it would remove the need for any of this mess with channels and tuning.
https://linustechtips.com/topic/765104-n64-problems/#findComment-9665100
am i right in thinking that there were 2 models of N64 ? one with an RF output and one with scart/composite ?
Home PC:
CPU: i7 4790s ~ Motherboard: Asus B85M-E ~ RAM: 32GB Ballistix Sport DDR3 1666 ~ GPU: Sapphire R9 390 Nitro ~ Case: Corsair Carbide Spec-03 ~ Storage: Kingston Predator 240GB   PCIE M.2 Boot, 2TB HDD, 3x 480GB SATA SSD's in RAID 0 ~ PSU:    Corsair CX600
Display(s): Asus PB287Q , Generic Samsung 1080p 22" ~ Cooling: Arctic T3 Air Cooler, All case fans replaced with Noctua NF-B9 Redux's ~ Keyboard: Logitech G810 Orion ~ Mouse: Cheap Microsoft Wired (i like it) ~ Sound: Radial Pro USB DAC into 250w Powered Speakers ~ Operating System: Windows 10 Enterprise x64
Work PC:
CPU: Intel Xeon E3 1275 v3 ~ Motherboard: Asrock E3C226D2I ~ RAM: 16GB DDR3 ~ GPU: GTX 460 ~ Case: Silverstone SG05 ~ Storage: 512GB SATA SSD ~ Displays: 3x1080p 24" mix and matched Dell monitors plus a 10" 1080p lilliput monitor above ~ Operating System: Windows 10 Enterprise x64
https://linustechtips.com/topic/765104-n64-problems/#findComment-9668174
Your TV likely defaults to the antenna/digital setting when it comes to using coaxial or whatever the fuck it's named.
Make sure it's set to analog and go from there, or better yet, buy S-Video cables for it. They're really cheap.
https://linustechtips.com/topic/765104-n64-problems/#findComment-9669264
most tv today have to be autotuned.
plug in the n64 and turn it on
now do a antenna tv auto scan
if that fails on your remote type 3.0 or 4.0
the .0 tell tv analog mode
i had a local tv broadcasting agency that took awhile for them to understand that you do not put your tunein information on the .0 but tie it with .1 stream
if all else fails hook a vcr up to tv using red white yellow rca and n64 to vcr then select chan 3 or 4 on the vcr
https://linustechtips.com/topic/765104-n64-problems/#findComment-9671000
No, because RF output is handled by a separate module which can be unplugged if a scart cable is more the choice for connecting it to a TV (if you look at the back, the connection (which is the same one used for AV out on the SNES and the gamecube) is recessed into the system so that the RF connector when it is plugged in is flush to the back of the system).
https://linustechtips.com/topic/765104-n64-problems/#findComment-9671055
It's interchangeable sort of, but not all consoles can output the same thing, and it varies by region. For example if you took an RGB scart cable from the PAL region Gamecube, it would plug into the N64, but it wouldn't work as the N64 can only output RF & Composite for PAL region* or RF, Comp, & S-Video for NTSC.
*The original dark grey PAL N64s can be persuaded to output S-Video using a custom cable, but the later transparent ones are limited to component. PAL N64s are a bit rubbish TBH.
https://linustechtips.com/topic/765104-n64-problems/#findComment-9674737
