Bugged Cpu Fan?
Go to solution Solved by simtransporter,
CPU fan is controlled using PWM by the motherboard. You should be able to adjust this setting in the UEFI (BIOS)
My cpu fan has always been loud. I've noticed that the fan speed always stays the same. So I was wondering if it was possible to reduce cpu fan speed? The temperature of my cpu stays around 40C and considering my PC is actually designed to be quiet, its just the cpu fan. I don't really want to change out the cpu cooler. I have what I believe to be *moderate* pc knowledge.
Parts of importance.
http://www.gigabyte.com/products/product-page.aspx?pid=4305#ov
http://www.arctic.ac/eu_en/products/cooling/cpu/freezer-7-64-pro.html
http://shop.amd.com/uk/All/Detail/Processor/FD6300WMHKBOX
"Lost in the woods, but DAMN these trees are cool!"
https://linustechtips.com/topic/76487-bugged-cpu-fan/
It's either in the BIOS, or use Speedfan.
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/76487-bugged-cpu-fan/#findComment-1049478
Yes you can change CPU fan speed and you can just replace the fan which is pretty darn cheap :)
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
https://linustechtips.com/topic/76487-bugged-cpu-fan/#findComment-1049483
