Working on a build for my friend (tron build) and he received a damaged window on his s340 side panel, well they send a whole new side panel instead of just the window. So, we aren't quite sure what to do with the damaged one any ideas??
The Vinyl Decal guy.
Celestial-Uprising  A Work In-Progress
https://linustechtips.com/topic/764168-side-panel-mod/
i think a new whole side panel
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/764168-side-panel-mod/#findComment-9653575
I would agree, unless you used plastic wrap or had a big enough piece of acrylic lying around or something like that.
https://linustechtips.com/topic/764168-side-panel-mod/#findComment-9653590
This may be a bit too dull/basic for you but you could take out the acrylic window and try to replace it with TG. If it goes wrong, you still have the new one.
WHIPLASH
CPU: Intel Core i7 6700k @4.7GHz
RAM: Corsair Vengeance RGB DDR4 2x8GB @3000MHz
MOBO: Asus ROG Maximus VIII Ranger
GPU: EVGA GTX 1080 FTW2
PSU: EVGA Supernova 650GS
CASE: Fractal Design Define S
https://linustechtips.com/topic/764168-side-panel-mod/#findComment-9653594
aww come on, golden opportunity imo since if i mess this one up beyond repair it doesn't matter
https://linustechtips.com/topic/764168-side-panel-mod/#findComment-9653599
Also: Check this out: This guy made a side panel that's basically an LCD screen. Really cool if you can pull it off
WHIPLASH
https://linustechtips.com/topic/764168-side-panel-mod/#findComment-9653601
my ideas:
1.make it a fish tank
2. put it over an outside window and cut cardboard around it so when you look in the case window you're looking outside. (might look ugly from outside tho)
3. wall or shelf decoration/ backdrop arts and crafty type thing
linus sex tips
https://linustechtips.com/topic/764168-side-panel-mod/#findComment-9653684
Like the looks of this, but 90 bucks for just the panel is a bit pricey
9 minutes ago, wii8cookies said:
my ideas:
o.O fish tank...broken window to outside?... well art i guess?
I was thinking more about making it look like a broken mad maxish side panel or something
https://linustechtips.com/topic/764168-side-panel-mod/#findComment-9653733
