Just now, EasonIDontKnowAnything said:
I found out how to. but for now should I just scan or factory reset I need your opinion
Scan first to rule it out, then reset if necessary. Also I can see you say you are going to build a i3/i5 pc correct? If I were you I would wait for the ryzen 3 and or the 5 series to come out. Ryzen 5 comes out in a week.
https://linustechtips.com/topic/764024-need-help-asap/page/2/#findComment-9652175
im too poor :)
https://linustechtips.com/topic/764024-need-help-asap/page/2/#findComment-9652178
Also Probs get a rx 460 or gtx 1050. Way better performance at a small price increase.
https://linustechtips.com/topic/764024-need-help-asap/page/2/#findComment-9652179
Then save. Don't settle for a poop pc when you can save a little more for a better one. The price difference really isnt that bad.
Like if you were to get a ryzen 3 1100 or 1200 "when available", a gtx 460 or 1050(or even a rx 560 "when available"), a cheap am4 mobo, and 4gb of ddr4 ram that would be a sick little affordable gaming pc.
https://linustechtips.com/topic/764024-need-help-asap/page/2/#findComment-9652186
45 minutes ago, EasonIDontKnowAnything said:
wait so If I download the iso file and do a clean install I wont need to put in the cd key orrrrrrr
If the license for Windows is legit, you can use Nirsoft's ProduKey to recover the key for reinstallation.
https://linustechtips.com/topic/764024-need-help-asap/page/2/#findComment-9652230
1 hour ago, EasonIDontKnowAnything said:
So I posted posts about this for a while now last 3 months. And it only happned when I used Google Chrome. If you don't know what "it" is. It's basically this thing that happens when I use google chrome. The svchost.exe spikes up as high as 500,000k , and just know I just uninstalled google chrome and now using good ol maxthon browser. And it seems like this "it" has crawled from Google Chrome to this browser too when I use it. And I would do a format but this guys charges me too much for it. And I would do a clean install of windows but when I put in the CD key at the windows website it would just say Error. So yeah. I cri evertime pls help.
You still haven't formatted and reinstalled windows? hehe
https://linustechtips.com/topic/764024-need-help-asap/page/2/#findComment-9652246
36 minutes ago, DiGiTaL FaKiE said:
Like this would be a great budget build. Factor in 150-175$ extra due to the missing unreleased ryzen 3 cpu from the part list cpu. https://pcpartpicker.com/list/DYkXNN
I just found out after I close Maxthon browser the high usage svchost.exe also closes and goes away. That mean the virus lies in the folders of mxthon right.
https://linustechtips.com/topic/764024-need-help-asap/page/2/#findComment-9652270
Could McAfee finally solved this problwem fir me? :") All I ned to do now is to restart my pc and turn mcafee off and see if everything is truly fixed.
https://linustechtips.com/topic/764024-need-help-asap/page/2/#findComment-9652354
https://linustechtips.com/topic/764024-need-help-asap/page/2/#findComment-9652376
No that just means that browser uses that amount of ram.
https://linustechtips.com/topic/764024-need-help-asap/page/2/#findComment-9652727
nah man I mean the svchost.exe things is straight up weird. After starting up Maxthon. It will come and start taking all this ram up in a minute or two. but after me ending the process two sperate times. It would stop popping up and everything would be fine.
https://linustechtips.com/topic/764024-need-help-asap/page/2/#findComment-9652733
Welp then reset it.
https://linustechtips.com/topic/764024-need-help-asap/page/2/#findComment-9652738
