So I have my Ryzen CPU clocked to 3.9 Ghz at 1.4 volts and it's stable (although I can only do 1-2 cinebench test runs in a row before it crashes) and was just curious if these reports here are fine. (Note My CPU Vcore once jumped to 2.1v out of nowhere and stayed there any ideas opn what that was?)
https://linustechtips.com/topic/763877-ryzen-questions/
If you can only do Cinebench once or twice, lower the clock.
B.S.O.D.! Roll it down.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650555
Not sure, I've heard of reporting issues with voltage on Ryzen but not 100% certain on them.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650558
It's never BSOD on me, just locked up. I assume it's fine since I doubt I'll use a program that takes up 100% of all my clocks but.
I'll lower the clock though if you think I should.
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650575
Still not good. AT ALL.
You're using a program that has a set method of operations as a benchmark. The benchmark shows you instability when working in a stable workload.
When you add random data, i.e. gaming, you're gong to have issues.
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650591
Ah alright
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650594
3 minutes ago, AdmiralMeowmix said:
Ah alright
If it is locking up on cinebench that means it'll lock up while gaming. Definitely not stable.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650609
I mean if it can't do more than one or two benchs, then it isn't exactly stable?
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650618
I guess I don't realize what stable is then aha I'm new to this.
Lowered it down to 3.8 and it's now actually stable I can do 5+ cinebench tests in a row with no issue
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650628
Yes once I managed to do a full Heaven Benchmark on my Maxwell Titan X clocked at 1820mhz, which is insane... but obviously 9/10 times it would just crash on the first 5 seconds, just because it works doesn't mean it is stable, stability means it can function for very long periods of time without any interruption at such clocks [:
Personal Desktop":
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650635
Ah I see. Well I'll do some more stress testing and see. I'll be fine with 3.8 xD
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650643
That is not stable.
I run my R7 1700 at 3.8 GHz 1.275V, I was not able to get it stable at 3.825 GHz or higher even with pushing voltages through the roof. Each chip is different though.
In order to test overclocks I run three multithreaded cinebench, then one singlethreaded cinebench, followed by at least 24 hours of what I intend to run on the system (x265 encoding). If it crashes, it needs more voltage or lower clock.
Ryzen doesn't really BSOD, it either locks up or blacks out.
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650651
2 minutes ago, DrMikeNZ said:
That is not stable.
Yea it's now stable at 3.8 at 1.4 volts
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650663
Haha no worries. To ensure it's stable I'd recommend running either Aida 64 or Asus Realbench for 30 min-1 hr to ensure it's stable.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650706
I plan on doin OCCT for a bit. Got the voltage down to 1.375 presume stable since I could do 7 cinebenches in a row with no issues
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650710
Lower voltage is always good. See how far you can push the memory, since that seems to make more of a difference on Ryzen than core clock speed.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650716
1 minute ago, AdmiralMeowmix said:
Memory is at 3200 Mhz stable
What memory specifically is it?
You could see if you could push it further. 3466 MHz and 3600 MHz have shown pretty large gains in some games. Just look at 2933 vs 3466:
http://www.gamersnexus.net/hwreviews/2865-ryzen-revisit-ram-overclock-windows-update-efi-updates/page-5
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650734
Nah it's rated at 3200 Mhz it's corsair vengenge LPX
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650776
Yeah but you could OC :D
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650816
That IS the OC though, all RAM is 2133 Mhz base but the listed Mhz is the max OC that it is rated for. You can't do any higher in the Bios and trying to force it would probably kill the RAM a lot faster.
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650950
Yeah well I'm talking about OCing past it's rated. You could probably try for 3466 or 3600, if you wanted. Unless you up the voltage it shouldn't  make it die much quicker.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/763877-ryzen-questions/#findComment-9650958
