OnePlus 3T or Samsung S7 Edge
Just now, themctipers said:Camera
Alright, I'll give the GS7 a win in this department, but not by a huge margin. the OP3T Camera is still amazing, just not at the "Legendary" status of the GS7
1 minute ago, themctipers said:display
Display is a moot point IMO. both use an AMOLED panel, and although the GS7 is higher resolution, who actually cares in daily use if your phone is 1080p or 1440p. the only advantage is mobile VR, which sucks and nobody should use. the edge screen is a gimmick, because there's no use for such a technology.
2 minutes ago, themctipers said:build quality (feel in hand)
That's debatable. the 3T uses a really nice design. I'd call this one a draw IMO, because both are made of premium materials, and glass vs metal is a preference thing.
4 minutes ago, themctipers said:performance
Untill now, your points have made sense.
but.. are you serious?
how could you possibly dream that the GS7 is faster or preforms better than the OP3T in any way. it has a heavily skinned version of android, which even though touchwiz has improved since the GS5 days, is still much slower than stock/near stock. the OP3T uses an objectively faster processor (SD820 VS 821), and any speedtest you will ever watch shows the 3T as a clear winner. just look at phonebuff.
