Hello i want to know how much ( not IF ) my cpu will bottleneck , i want to upgrade to a high end card , even though i know i dont really have the cpu for it.
my cpu is a amd fx 8350  AM3 Socket  with 32gb of DDR3 ram. ( i am planning to upgrade these but these things wont be upgraded soon )
i've checked a site to see what things would bottleneck my cpu. and so far it has said    1080 (13% bottleneck)   and a titan x ( 15% bottleneck ) it wasn't able to check for 1080ti and titan xp which was a bummer.
15% was still in the green area though so you'd still get "most" out of it but not its full potential. which i can deal with i can always upgrade my stuff later. but for now i'd have to live with a high-end gpu and a mid-end cpu.
how much would it bottleneck my cpu? i should still be in the green area if its under 20% bottleneck , and what would you recommend me getting out of the high end cards. in depth answers would be greatly appreciated. i am clearly not the best at this computer stuff but i really love it.
https://linustechtips.com/topic/763011-how-much-will-my-cpu-bottleneck/
what is this site?
Each game utilize cpu differently so there is no simple answer to your question
9 minutes ago, mrzoltowski said:
You laugh but  my old Intel Core i7-4930K @ 3.40GHz was causing a 15-18% drop in performance/FPS compared to my new i7 7700K with a GTX1080
Well, the i7-4930K is slower than the i7-7700K (3.9GHz turbo vs. 4.5GHz turbo) and most games today cap out at 8 threads. And it depends on the game.
Also that website you mentioned said the i7-4930K "will work great together"
Stupid copy paste, it was a 4790 no K, sorry (used to be from an old Lenovo Erazer)
What is your current GPU...Also If you will upgrade later(however long later implies) and have the money to get a 1080ti...then get the 1080ti and upgrade cpu etc...later. I would not stress too much about it. Unless you are going to wait years to upgrade your cpu platform
CPU: Ryzen 7 2700x cooled by Pure Rock Slim // RAM: Gskill Flare X 3200mhz CL14 2x16 32GB// GPU: Powercolor Red Devil RX 6650 XT 8GB// Motherboard: ASRock B450m Pro 4 // PSU: Seasonic G550 Gold 80+ // Storage: 4TB pcie nvme game drive, 512 GB m.2 sata3 OS Drive, 4 TB WD Red HDD // Monitor: Samsung S22D300 21.5" 1080p 60Hz, MSI 27" 1080p 144hz Freesync 1ms display // Peripherals:  Logitech fancy shmancy keyboard and moise with rgb and gaminess stuff, very fancy | Kingston HyperX Cloud Core headset
I am indeed planning to upgrade the cpu and motherboard+ram in like a year or less.  my current GPU is a geforce 960 (2gb)
1080ti and dont worry about it...if it fits your budget. If you wanna spend less get a 1080 or 980ti
