Well I got on my computer today, and had downloaded New Vegas on Steam before I left for school. I came home today and started to play but realized how I wasn't used to the xbox controller I had plugged into my PC (wireless adapter) so I unplugged the charging cable that turned off the controller, then the game crashed, and every time I tried to use it it crashes... Now if I use any non-system application and press ANY key on my keyboard the application automatically stops responding. I booted with safe mode and it seemed to work correctly. I ran a quick virus scan and nothing turned up, so I'm running a more thorough one now, it's really concerning me because I am hoping its not hardware failure because not many of my parts are say 'cheap'. Any help would be great.
PC Specs:
New Compact Build
CPU: i7 8700k (Delidded)  |  GPU: EVGA GTX 1070Ti ACX 3.0 Black  |  Motherboard: ASRock Fatal1ty Z370 Gaming  |  Case: EVGA Hadron Air
RAM: Corsair Vengeance LPX 16GB DDR4 3000MHz  |  SSD: Samsung 860 EVO 1TB  |  Monitor: ASUS PB287Q
     OS: Windows 10  |  Keyboard: Corsair Strafe RGB  |  Mouse: Logitech G502 Proteus  |  Headphones: Steelseries Arctis 5
Surface Book 2 15"
CPU: i7 8650U  |  GPU: GTX 1060M  |  RAM: 16GB DDR3
https://linustechtips.com/topic/76299-crashing-problem/
I will try this, I tried switching keyboards to an old mac one and the same issue occurred. I'm going to try to uninstall the xbox controller drivers once the security scan is finished just to insure it's not a virus.
PC Specs:
New Compact Build
Surface Book 2 15"
https://linustechtips.com/topic/76299-crashing-problem/#findComment-1046919
I uninstalled the drivers for my keyboard, the wireless adapter, and the problem persists. I even tried using the on-screen keyboard and the same thing happens as a physical keyboard.
About 40% way through the virus scan it said it found 1 virus
PC Specs:
New Compact Build
Surface Book 2 15"
https://linustechtips.com/topic/76299-crashing-problem/#findComment-1047122
what virus scanning software are you using and what is the Virus?  it sounds like a keylogger, trojan to me.  Or it might be rootkit or even a case of Virut.
https://linustechtips.com/topic/76299-crashing-problem/#findComment-1047511
Well I fell asleep last night so I'm going to check for the status right now, but I am using avast! free version
PC Specs:
New Compact Build
Surface Book 2 15"
https://linustechtips.com/topic/76299-crashing-problem/#findComment-1048390
I checked on the virus scan it was some kind of virus that was in a Windows Defender database, when I went to wipe it, it said it wasn't in the location that it thought it was.
PC Specs:
New Compact Build
Surface Book 2 15"
https://linustechtips.com/topic/76299-crashing-problem/#findComment-1048479
remove Avast.  Its a peice of crap! I would check with Windows Defender and make sure it hasn't been locked down or quarantined or anything.  After doing so I would download the latest version of Malwarebytes Anti-Malware and update it.  Run a full scan with that.  Then download AVG.  Avast literally ran my computer dry of all its resources.
https://linustechtips.com/topic/76299-crashing-problem/#findComment-1050323
I reinstalled windows, everything works fine now, I literally operate on the cloud with my near 300gbs of Dropbox space
PC Specs:
New Compact Build
Surface Book 2 15"
https://linustechtips.com/topic/76299-crashing-problem/#findComment-1053217
