Currently, using an old AMD system with FX 6350 and Radeon 7800 GPU. Constantly runs at 80 degrees (either under load or idle) and I really need an upgrade, so planning to build my first PC (first was prebuilt).
https://uk.pcpartpicker.com/list/yjL8sJ
This is my proposed parts list, plan to use this for music production and some gaming (R6 siege, CSGO, etc.).
Can't make my mind up on the cooler, as I'm not sure how much of a difference it would make for my use personally. I don't have a specifically set budget, but don't really want to spend tons on a cooler.
Also, RAM is ridiculously expensive here in the UK and I'm not sure how much of a difference the speed will make.
I should also point out that I'm going for a black and white themed build.
https://linustechtips.com/topic/762730-need-help-with-cooler-choice-ram/
As for the CPU I think it's a bit overkill, if gaming (non-VR) and music production are the main things you're going to do with it... The RAM looks really good for the price actually (here in Italy the prices are comparable) and the cooler seems good too. If you want best overclocking capabilities (again, probably not needed), you might want to go with a Noctua cooler (like the NH-D14) and replace the fans with Noctua black and white ones (or other good fans). This is a bit trickier and more expensive solution, but it'll give you quite some more room for OC
DESKTOP PC - CPU-Z VALIDi5 4690K @ 4.70 GHz | 47 X 100.2 MHz | ASUS Z97 Pro Gamer | Enermax Liqmax II 240mm | EVGA GTX 1070Ti OC'd
HOME SERVER | HP ProLiant DL380 G7 | 2x Intel Xeon X5650 | 36GB DDR3 RDIMM | 5x 4TB LFF Seagate Constellation 7.2K | Curcial MX500 250GB | Ubuntu Server 20.04
Looks good to me. I'd just roll with that setup.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
At this price range, wouldn't it be better to go with a Corsair H60 or is the Noctua better?
Don't waste money on a 120mm AIO cooler. They are not much better than a low end air cooler. The Cryorig H7 that you have in your list is a good choice, although they seem to be out of stock everywhere for some reason.
You could drop the psu down to 550W if you are just going with a single GTX 1070.
Yeah, this is a possibility, although I'd rather play it safe and go for a bit extra as I've had loads of problems with the PSU in my current PC.
I have just had a quick look on pcpartpicker and to be honest you are not really going to save any money by dropping down to 550W so you might as well roll with the 650W.
