120mm Fans
Guest Storm10
Any recommendations for 120mm fans that are quiet and good airflow?
Corsair has quiet edition and performance edition fans. I've used dozens of there SP (Static Pressure) and AF (Air Flow) series fans and never had a failure. They have newer models that are rgb capable as well.
i7 10700k @ 5.1Ghz, 1.37v | Asus Z490-E Strix | Asus Rtx 2080ti Strix | 16Gb Trident Z Rgb @ 3600MHz | Samsung 970 Pro | EVGA Supernova G2 850w  | Corsair 500D | Celcius s36 /w ML Pro's
i7 8700k @ 4.8GHz, 1.31v | Asus Z370-A Prime | Asus Gtx 1080ti Strix | 16Gb Corsair Dominator Platinum | Samsung 850 Evo | Corsair TX 650W  | Corsair 750D | Corsair H100i v2 /w SP-120's
Just now, Silentsoul said:
Corsair has quiet edition and performance edition fans. I've used dozens of there SP (Static Pressure) and AF (Air Flow) series fans and never had a failure. They have new models have that are rgb capable as well.
What are PWM fans?
5 minutes ago, Storm10 said:
What are PWM fans?
Are you asking which models are PWM?
No, what does PWM stand for and what makes it different than non-PWM fans?
PWM means they are a 4pin plug with controllable speed
3 minutes ago, Storm10 said:
What are PWM fans?
Fans with adjustable speeds via a 4th pin. Don't bother with non-PWM fans for cooling a personal rig, PWM can help keep your rig quieter at idle and cooler at load
beQuiet Silent Wings 3 are great, so are 2s
Anything Noctua (ugly tho)
Corsair ML's at lower RPM
Most Noiseblockers
Fractal Design Venturi = budget option
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
Hello there! I do understand LEDs may not be of preference, although I strongly recommend picking up a pair of Auoker White 33 LED Grid 120mm fans.
Review:
Achieving exceptionally heavy duty fan bearings at only £5.66 maximum budget is most clearly doubted by a vast amount of manufacturers. But Auoker didn't think this way. Striving ahead of it's cheaply constructed companions, Auoker succeeds in claiming there promise of a 'Low-Noise Design'. Brilliant lubrication of the Hydraulic Bearings does in practise prevent undesired noise output, whilst allowing a smooth rotation. Furthermore, awesomely impressive illumination of the fan's blades develop evenly over the blades, with no fade towards the central motor.
Included out of some impossible fate in box, all corners are securely dampened of vibration introduction by cleanly cut white rubber anti vibration mounting holes. Backdraft from the blades never is an issue, with channel airflow similar to that of some of Noctua's NF-F12s, thus not compromising on there claim of 'Built-in Wind Blocker Frame'.
Specifications:
Weight: 115g
Fan Size: 120 * 120 * 25mm
Fan Speed: 1200RPM ¡À 10%
Air Volume: 53.02CFM
Air Pressure: 1.073mm-H20
Input Power: 3.6W
Operating Noise: 16bBA
Input Current: 0.3A
Input Voltage: DC12V
3-Pin Fan and 4-Pin Molex connectors for full compatibility.
I once did the unthinkable, back many headphones ago...
I split an audio split, again
6 minutes ago, EnergyEclipse said:
-snip-
Want to make that normal font lol its huuuuuuge
HOLA NIGHT THEMERS
OTHER TECH I OWN:
This forum really confuses me sometimes. For me that is fairly standard sized text, although for others it appears mammoth in sizing? And with the Automatic colour issue, for me it is pure grey tinted white! xD
I made it smaller for you though :3
What resolution is your monitor? And what is your browser scaling?
Thanks tho
HOLA NIGHT THEMERS
OTHER TECH I OWN:
Thanks tho
No problem! Mostly my bad I would think xD I am horrible at writing.
Anyhow, my monitors are both 272 @ 2560 x 1440 resolution each. Browser scaling is I believe 100%. A few inches gap between this text box & the bezels
Have a great day!
-EnergyEclipse
Most Noiseblockers
This explanation is very weird.
PWM fan will maintain the fan speed even though there are restriction like dust filter or radiator in the flow path. With voltage/non-PWM control, the fan will slow down.
PWM model usually have lower minimum speed than its non-PWM counterpart.
However, both PWM and non-PWM models will have the same cooling performance/air flow if they run at the same speed.
For rear exhaust fan, maybe front intakes as well. Non-PWM fans are perfectly fine.
I understand PWM, although your definition that they will maintain fan speed through a restriction doesn't exactly make sense if I may admit. I do believe no fan is aware of restrictions and/or knowledgably to there CFM ratings/RPM, so any fan would unless manually controlled via external software ect.
Thank you!
-EnergyEclipse
Thank you!
-EnergyEclipse
Try to put a dust filter in front of a DC fan, the fan speed(rpm) will drop.
I did that awhile back...no difference in RPM when is was on/off it.
 As to why would such occur I question, since dust filters do indeed restrict airflow,  thus maybe a degree or so in temperature rise compared to without, so wouldn't the opposite happen if anything? I am rather confused.
Thanks again.
Thanks again.
I tested it myself awhile back. I did see drop of rpm, especially if the filter is cogged with dust.
Well, that is no surprise if the fan bearings/motors are clogged with dust! xD Limited movement rotates the blade at a slower RPM, as restriction/frictions are increased because of build up.
Thank you for your explanation! Have an awesome day.
-EnergyEclipse
-EnergyEclipse
I said the filter was cogged with dust. The fan was clean.
6 hours ago, Storm10 said:
What are PWM fans?
PWM describes how the fans are powered. Whether fan speed can be controlled depends on the header you're powering it from and not the fan itself.
@Storm10
Where are you using the fans?
Where are you shopping/located? Budget?
@Storm10
The front, top, rear, and the side. CA, USA. Under $75.
Every fan is "powered" the same way, with a ground on pin 1 and a positive on pin 2. Pin 3 is the tachometric signal which reports the rpm of the fan. A 3 pin fan can only have it's rpm reduced by reducing the voltage. PWM can reduce the rpm of the fan by rapidly cutting power on and off to the fan to maintain a certain value without dropping down from 12v.
What case are these going into? Color or LED preference? With your location ordering from Newegg.com should be very quick shipping when you have decided on a purchase.
Corsair 900D and blue LED.
4pin pwm fans have IC's that generate the pwm signal that determine how the power translates into rotation. 3pin fans aren't limited to dc and can be controlled by pwm as well but the header that the fan is plugged into is what determines this pwm signal for power instead of an IC on the fan. Phanteks' PWM Hub is one example of how 3pin fans can be controlled via pwm.
The same pins are used for power but pwm and dc don't power the fan in the same way.
What components are you cooling? Why 120mm fans in a case that supports 140mm's and why such a large case in the first place?
