First of all do you just want to play games or do you want to do video editing and rendering?
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/761915-pc-help/#findComment-9627670
2 minutes ago, Samuel Jones said:
Ok this is my first build that's why I keep posting.
1. DO I need a fan controller?
2. Do I need a sound card?
https://pcpartpicker.com/list/sJgG6X
I actually wanted an all white/gold/purple build.
Also please let me know of any other possible issues.
I think your motherboard comes with built-in audio, so no.
https://linustechtips.com/topic/761915-pc-help/#findComment-9627678
You don't need a fan controller unless you want fanciful fan speed control and you don't need a sound card as most modern motherboards have integrated audio. People get sound cards if they are picky about sound or they have an older motherboard
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
https://linustechtips.com/topic/761915-pc-help/#findComment-9627679
1 minute ago, Samuel Jones said:
editing and rendering thats why I got ryzen. I may play few games like warframe or neverwinter. ill use legato as well
Okay
زندگی از چراغ
https://linustechtips.com/topic/761915-pc-help/#findComment-9627778
That psu is cheap
That case is also cheap
https://linustechtips.com/topic/761915-pc-help/#findComment-9627785
54 minutes ago, Samuel Jones said:
@knightslugger and @herman mcpootis and any others
No you will not need a fan controller. There are three chassis fan headers on the board, which will control all possible fan mounting solutions in that case (3x120mm, 2 front one rear).
There is onboard audio, so no need for a sound card unless you need something specialty.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/761915-pc-help/#findComment-9628015
10 minutes ago, Samuel Jones said:
@knightslugger and how many fans do I need to get? 3 right?
You get 1 fan with the case already, so if you wanted to max out the capacity you'd need to buy 2 more. I see there is one in your PCPP already. just add one more and you're all set.
you might reconsider the PSU though to a modular type. that's a rat's nest.
System specs:
https://linustechtips.com/topic/761915-pc-help/#findComment-9628500
Just now, Samuel Jones said:
@knightslugger This psu or which do you recommend? And how do I make pc Bluetooth?
You'd have to add on a blue tooth adapter, either USB or PCIe.
For a PSU, a EVGA 550 G2 would be a solid choice.
System specs:
https://linustechtips.com/topic/761915-pc-help/#findComment-9628607
