Need help connecting subwoofer
1 hour ago, anothertom said:What you've got yourself there is a powered sub, so it has an amplifier built in. What you want to do is split the signal that's going to the amp for your mid-tops and send it directly to the sub. Seeing as you didn't say what amp you're using, it may or may not have a dedicated sub output (generally a receiver should have one, an actual amp won't), so you may be able to run a stereo RCA cable to the sub or you may need some RCA splitters as well.
I just realized my sub has an LFE input. It has a l and r for rca but it says in the desc there's also LFE. It's a Klipsch 10 inch reference series. My amp is a nobsound tpa3116d2. It's small and whatever but it has 9 banana plug inputs, 4 for speakers and 2 titled sub. What do I need to buy and plug what into what? I'm pretty stupid with stuff like this apologies
