Wireless speakers options (Multi-room)
I've already looked at offerings like Sonos but I find this quite expensive.
I would need something that would work in multiple rooms via the use of multiple speakers which aren't too expensive.
It is going to be used as a sort of background music in a garage/store area and I could plug it into a PC or maybe bluetooth/wifi.
I've thought of using cable but as the area is pretty big I don't think the cable will hold the signal so wifi might be a better option.
@SSL You know anything about these things?
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/761476-wireless-speakers-options-multi-room/
Ultimate Ears (UE)
Since I am to lazy to put something interesting here, I will put everything, but slightly abbreviated. Here is everything:
42
also, some questions to make you wonder about life:
What is I and who is me? Who is you? Which armrest in the movie theatre is yours?
also,
Welcome to the internet, I will be your guide. Or something.
My build:
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor,
 Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard,
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory,
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive,
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card,
Case: Corsair 100R ATX Mid Tower Case ,
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply,
Operating System: Microsoft Windows 10 Home Full,
Wireless Network Adapter: TP-Link TL-WN725N USB 2.0 802.11b/g/n Wi-Fi Adapter, Case Fan: Corsair Air Series White 2 pack 52.2 CFM  120mm Fan
ou do not ask why, you ask why not -me
Remeber kinds, the only differ between screwing around and scince is writing it down. -Adam Savage.
Only two things are infinite: the universe and human stupidity, and I'm not even sure of the former. - Albert Einstein.
A cat5e cable will hold a signal for 100m, assuming the connections and equipment are of decent quality. As for your question, I like using raspberry pi's and pi music box (http://www.pimusicbox.com/) to connect my iphone and itunes to my stereo system. It involves some DIY, but it has great flexibility and is super cheap.
Cheers!
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
Cheers!
Never heard of it, sounds wonderful a solid option. Only issue now is that I need to think about the speakers which I also asked about.
12 minutes ago, King_of_Oz said:
Ultimate Ears (UE)
Yeah I know these ones but I want a more permanent solution and less expensive as these can rack up if you buy enough. I like the suggestion from @dany_boy but that doesn't include speakers.
