watercooling help new to water cooling and need some help
Solved by W-L,
1 minute ago, TacticalBigBoss said:-SNIP-
Welcome to the Forums!
That list looks good, I would personally recommend to go with the D5 pump, it's one of the best regarded units out there, and will be more than enough for a single CPU and GPU loop. However I would go with a tube res over the bay units as they are tricky to fill and bleed the loop.
Also you have both clear and UV purple fluid selected.
