so for some reason i have really bad internet its fine unless anyone less uses the internet then its out the window i live in a house with 7 people.... so ye is there anything i can do other then pluging my pc in via ethernet to get bandwith priority over others (basicly my lil bro who has is laptop ps4 and xbox1 all on at the same time...)
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/760565-network-issues/
What are the download and upload speeds of your internet plan?
https://linustechtips.com/topic/760565-network-issues/#findComment-9612325
unlimited data download but speed idk
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/760565-network-issues/#findComment-9612332
Just now, CatXice said:
unlimited
There is not such thing as unlimited upload and download...
https://linustechtips.com/topic/760565-network-issues/#findComment-9612337
ye i know its limited by the line speed i know that but is there anythin i can do to give my pc priority over other devices
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/760565-network-issues/#findComment-9612345
1 minute ago, imreloadin said:
Ok, that's your data usage. What are the speeds of the plan? Is it like 20Mbps down and 5Mbps up?
idk coz i dont pay the bill so ye but a speed test is sayin 16.6 and 4.6mbps
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/760565-network-issues/#findComment-9612350
What are your speeds?
http://www.speedtest.net/ use this.
https://linustechtips.com/topic/760565-network-issues/#findComment-9612355
i posted it above
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/760565-network-issues/#findComment-9612358
i posted it above
Okay, you've got 7 people living at the home with slow speeds.. That's the problem. Speak to your parents if they can get a better connection.
https://linustechtips.com/topic/760565-network-issues/#findComment-9612371
ran the test 3 times got 16.6 13.7 and 16.6 on download 4.6 4.6 and 4.6 upload
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/760565-network-issues/#findComment-9612377
Ok, so my guess is you have a 15Mbps down and a 5Mbps up package.
The reason your speeds tank when you have multiple people using the internet at the same time is because you then take those speeds and divide them by 2 or 3 or 20 or however many devices are on at the same time.
The only way you can give yourself priority over other traffic is if your router has something called Quality of Service or QoS on it which allows you to limit the available bandwidth of people on the network and give more to yourself. So you'd have something like 10Mbps down and 3Mbps up while everyone else shared the remaining 5 down and 2 up. I'm guessing you're using the router provided to you by your ISP so my guess is that you're not going to have the QoS option.
https://linustechtips.com/topic/760565-network-issues/#findComment-9612382
i know u can QoS but coz sky like to bend u over a table guess what there routers dont have it
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/760565-network-issues/#findComment-9612389
If you know about QoS and that your router doesn't have it then what is the point of this topic?
Your router will always try to split the bandwidth evenly across all of its users without overriding it with QoS so your only option is to either get a faster internet package or only get on when others aren't online as well. I guess you could get a different router that has QoS but then you'd usually have to get a different modem as well if your ISP gave you a router/modem combo unit, which most do as it's cheaper.
https://linustechtips.com/topic/760565-network-issues/#findComment-9612412
