Looking For A Small Wifi Extender
Sadly I don't think I have encountered anything that is a perfect solution. I think a cheap router would probably be your easiest solution, especially if you have some spare on hand.
1 possible alternative which I think may work for you (Assuming I understand you properly) is This. It doesn't use a wireless signal rather your homes own electrical circuit to connect the 2 modules and as far as I can tell it won't rebroadcast as a wireless access point. According to newegg it also has a low power draw of <2w. I think the main disadvantage would be that it does not seem to be configurable in anyway, it is just plug and play.
Hope this helps.
p.s Amazon do have a 200mbs version if you are not joking about a low bandwidth device.
