So I built my new pc, it turns on, every part lights up or spins but I can't see my screen. I've tried clearing cmos and checked every plug. it isn't my monitors fault because I've tried hsmi dvi and a million combinations.
Specs:
Msi z170a m7
Gtx 1070
Deep cool captain 240ex
Phanteks enthoo evolv
16gb vengeance led ram
I7 7700k
Evga 850 g2
https://linustechtips.com/topic/759303-help/
Specs:
Msi z170a m7
Gtx 1070
I7 7700k
Evga 850 g2
It is quite likely (given post-code 62) the motherboard you have has an older bios which does not support that cpu. In that case you will need to flash a newer bios using a cpu that works with the existing bios.
~ Luc Luc
https://linustechtips.com/topic/759303-help/#findComment-9596483
Just now, caseyf said:
Idk prob not, I don't really want to anyway. I bought the Mobo in december.
I can't get another CPU, is that the only option....?
Unfortunately, yes.  If you can return the 7700K you can get a 6700K for a little less.  If not, borrow a skylake CPU from a friend maybe?
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/759303-help/#findComment-9596680
You can try to find a computer shop that will flash the bios for you. Or purchase a cheap skylake cpu to update the bios.
I had to do the same thing to update my z87 board. The nice thing is you will have a spare cpu for an emergency.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/759303-help/#findComment-9597093
