Hello, building a new computer from an old chassi i already have.
I'd like to know if the parts i picked out work together.
Chassi; Cooler Master CM Force 500 Midi Tower
Parts: GeForce GTX 1050Ti 4GT OC 4GB GDDR5
          Kingston HyperX Fury DDR4 2133 PC4-17000 8GB 2X4GB CL14
          Intel i7-6700K 4.0Ghz
          MSI Z170A Gaming M3
          Corsair RM750i 750W 80 Plus Gold Modular
Already have a hard-drive that works great just want to know if the motherboard will fit in the chassi and if all parts are compatible
Thank you beforehand!
https://linustechtips.com/topic/758076-building-new-need-help/
Just now, Sebastian asdf said:
I'd like to get in to streaming and a friend told me an I7 would be best then
Thank you for your reply!
wait a few weeks for a ryzen 6 core to come out at 250$. that will be a good streaming chip, then get a rx470, 480 or 1060
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/758076-building-new-need-help/#findComment-9582166
I'm pretty sure ryzen is more cost effective in that case, but I can understand if you don't wanna get into a platform that's not 100% complete atm.
https://linustechtips.com/topic/758076-building-new-need-help/#findComment-9582168
I would wait for the Ryzen 5 and maybe opt for a better GFX for the money. Ryzen 5+ RX 470/480 is a much better bang for your buck than an i7 plus 1050/ti.
https://linustechtips.com/topic/758076-building-new-need-help/#findComment-9582248
yeah but an GTX card with H264 and gefoce streaming would be better than an AMD card
https://linustechtips.com/topic/758076-building-new-need-help/#findComment-9582252
I completely overlooked the fact that streaming was a priority for you. Shadowplay is a great and easy way to stream. However, my point still stands; I still think that you should opt for a better graphics card than the one you are thinking of getting. Ryzen 5 should enable you to take some money out of your CPU budget and allow you to buy a better graphics card.
https://linustechtips.com/topic/758076-building-new-need-help/#findComment-9582279
I agreed with that. a 1060 would be the right card. Also I was not the OG poster
Edited by GDRRiley
https://linustechtips.com/topic/758076-building-new-need-help/#findComment-9582284
