why spend so much on 8gb of ram? a cx450m or s12ii would do the job just as well but much cheaper.
2 minutes ago, BluJay614 said:
Try to keep things under the same topic. I'd also put this under New Builds for future reference. What is your budget and what are you planning on using the computer for?
around $850 for the hardware only and moderate to heavy gaming
what i'd recommend:
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($239.99 @ Amazon)
Motherboard: MSI H81M-E33 Micro ATX LGA1150 Motherboard  ($44.89 @ OutletPC)
Memory: PNY Anarchy 16GB (2 x 8GB) DDR3-1866 Memory  ($79.99 @ Amazon)
Storage: ADATA Ultimate SU800 256GB 2.5" Solid State Drive  ($74.99 @ Amazon)
Storage: Seagate Pipeline HD 1TB 3.5" 5900RPM Internal Hard Drive  ($43.99 @ Newegg)
Video Card: Sapphire Radeon R9 Fury 4GB NITRO Video Card  ($265.91 @ Jet)
Case: DIYPC DIY-J21-W ATX Mid Tower Case  ($44.97 @ Newegg)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($49.90 @ B&H)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($30.00)
Keyboard: Redragon S101 Wired Gaming Keyboard w/Optical Mouse  ($24.99 @ Amazon)
Total: $899.62
Generated by PCPartPicker 2017-03-25 00:43 EDT-0400
Just now, Jaidenortiz7 said:
performs the same as the gtx 1060 6gb and 11fps better than the gtx 970 on average.
If I were you, I would definitely consider spending a little extra and getting an i5 6600, or 6600k if you plan on getting a z170 or z270 board down the line.  Also, love the white color scheme you seemed to have planned out, I'm also rocking a white setup.
GPU: ASUS Strix GTX 1070,  CPU: i5-6600k OC to 4.0 GHz,  PSU: Rosewill Capstone G750 750W,  Mobo: MSI Z170A Krait Gaming,  Case: NZXT H440 White,  Memory: G.Skill Ripjaws V 16GB (2x8),  HDD: Seagate Barracuda 2TB, Mouse: Razer Ouroboros,  Keyboard: Razer BlackWidow Chroma, Mousepad: Razer Overwatch KB+M pad, Headset: Corsair Void RGB,  Monitor: 1x ASUS PB277Q 27" 1440p & 1x HP Pavilion 25cw 25-inch 1080p
4 minutes ago, herman mcpootis said:
what i'd recommend:
Total: $899.62
Did you know that the cheapest 16gb ddr4 is also pny anarchy (or it was)
3 hours ago, herman mcpootis said:
what i'd recommend:
Total: $899.62
Don't think the Xeon e3 would be very good for gaming.
still is according to PCPP. still waiting for ram and ssd prices to drop back to last year's pricing
it's just an i7 4770 clocked 100mhz less, no reason why it wouldn't be as good as an i7 for gaming.
Get a higher quality PSU rather than a higher wattage one, the motherboard will look weird because of its color scheme and the fact that its mATX. Also that Wi-Fi adapter will be slowwwwwwww
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Still think he would be better off with an i5 7600 or even 6600 and a b/h150 board.
Yeah.  I would recommend getting an actual PCI-E WiFi card.
Sorry for the mess!  My laptop just went ROG!
"THE ROGUE":  ASUS ROG Zephyrus G15 GA503QR (2021)
  • Ryzen 9 5900HS
  • RTX 3070 Laptop GPU (80W)
  • 24GB DDR4-3200 (8+16)
  • 2TB SK Hynix NVMe (boot) + 2TB Crucial P2 NVMe (games)
  • 90Wh battery + 200W power brick
  • 15.6" 1440p 165Hz IPS Pantone display
  • Logitech G603 mouse + Logitech G733 headset
"Hex": Dell G7 7588 (2018)
  • i7-8750H
  • GTX 1060 Max-Q
  • 16GB DDR4-2666
  • 1TB SK Hynix NVMe (boot) + 2TB Crucial MX500 SATA (games)
  • 56Wh battery + 180W power brick
  • 15.6" 1080p 60Hz IPS display
  • Corsair Harpoon Wireless mouse + Corsair HS70 headset
"Mishiimin": Apple iMac 5K 27" (2017)
  • i7-7700K
  • Radeon Pro 580 8GB (basically a desktop R9 390)
  • 16GB DDR4-2400
  • 2TB SSHD
  • 400W power supply (I think?)
  • 27" 5K 75Hz Retina display
  • Logitech G213 keyboard + Logitech G203 Prodigy mouse
Other tech: Apple iPhone 14 Pro Max 256GB in White, Sennheiser PXC 550-II, Razer Hammerhead earbuds, JBL Tune Flex earbuds, OontZ Angle 3 Ultra, Raspberry Pi 400, Logitech M510 mouse, Redragon S113 keyboard & mouse, Cherry MX Silent Red keyboard, Cooler Master Devastator II keyboard (not in use), Sennheiser HD4.40BT (not in use)
Retired tech: Apple iPhone XR 256GB in Product(RED), Apple iPhone SE 64GB in Space Grey (2016), iPod Nano 7th Gen in Product(RED), Logitech G533 headset, Logitech G930 headset, Apple AirPods Gen 2 and Gen 3
Trash bin (do not buy): Logitech G935 headset, Logitech G933 headset, Cooler Master Devastator II mouse, Razer Atheris mouse, Chinese off-brand earbuds, anything made by Skullcandy
