Is it bad to buy the pc parts from different companies, like Newegg, Amazon, and so on. It'll be easier to buy them all on one website only problem is one place has it cheaper. That's what pcpartpicker does automatically unless set to manual vendors . If bought from one place it'll be easier to pay just one shipping fee instead of several. I have Amazon prime but some parts aren't prime. How do you all think I should order parts?
https://linustechtips.com/topic/757186-pc-parts/
My desktop includes parts I bought when I was travelling. Don't see how that'll make a difference.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/757186-pc-parts/#findComment-9573145
Going with the cheapest options makes the most sense to me, might be a pain but sometimes you can save so much doing it that way you can actually have enough money left over for another part
https://linustechtips.com/topic/757186-pc-parts/#findComment-9573174
i get things where they are the cheapest. makes no sense to me to spend more then i have to. sure i might not get everything at once but i dont care if i saved myself more then an icecreams worth of money
Builds:
https://linustechtips.com/topic/757186-pc-parts/#findComment-9573239
