Hello guys
I am an student in "RVT" trying to get a certificate in IT technician. One of my works for now is to make a essay about each part of pc and how to test it, troubleshoot and stress test. Now I need to make a table full of possible defects for each component and how that was introduced and how to get rid of it, for an example for GPU - blown caps, miss handling, manufacturing problem, burned dye from over volting, damaged power connector, snapped pcb, GPU not detected by windows, can see artefacts on screen, not running on all possible speed, crashed windows and so the list goes on and on.
so can you help me and cal all posible defects for - CPU, Motherboard, GPU, RAM, PSU, HHD, SSD, SSHD and CD-ROM
my work as far as it is for now (it is in Latvian) - https://drive.google.com/file/d/0B_VN1fzhcq6CQjItRlM3OG85M1U/view?usp=sharing
https://linustechtips.com/topic/757098-final-work-about-testing/
Just now, Matiasqooo said:
well i need help to list all possible defects in English
so i have some info to continue the work
gpu:
temp
voltage
capacitor
bad motherboard
physical damage
water damage
bad vram
bad gpu (die, eg G104)
power surge
bad power input (unstable)
cpu:
temp
voltage
bad motherboard (fried cpu)
physical damage
bad die
power surge
bad power input
motherboard:
bad PCB tracings
bad capacitors
water damage
power surge
bad power input
bad mosfets
ill keep on going later.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/757098-final-work-about-testing/#findComment-9572054
1 minute ago, themctipers said:
gpu:
temp
voltage
capacitor
bad motherboard
physical damage
water damage
bad vram
power surge
cpu:
temp
voltage
physical damage
bad die
power surge
bad power input
motherboard:
bad PCB tracings
bad capacitors
water damage
power surge
bad power input
bad mosfets
thanks for this and i also need defect things that some basic home user could see like blue screened pc or crashed when trying to connect to network  (LAN card also needed) or when playing games the pc freezes (that is cpu) more is like - can see artefacts on screen (GPU)
https://linustechtips.com/topic/757098-final-work-about-testing/#findComment-9572076
Well, it's quite insane to document everything but anyway, i got some suggestions :P
cd-rom:
broken laser
damaged laser (scratches for example)
dusty laser
broken motor (cd doesn't spin)
gearing broken (doesn't open or close)
No power
Wrong laser (blu-ray cd can't be read by a dvd reader, more of a user error tbh)
hdd:
weird noises
random freezes
corrupted files
broken motor
hdd unreadable due to physcial damage by the read/write head (scratches)
broken due to user dropping it. (more common than you might think)
psu:
burned down house, obviously :D
Jokes aside, it is a possibility a house actually burns down due to a bad psu.
Human death, also possible, the thing can short out and if a human was touching the case at that point it's possible the short kills the person.
Or you are stupid, open the psu and short out the cap, if the cap is still charged it could release a deadly shock.
PSU's are dangerous things and by far the most scary part of a PC. You might think it's fine when it's unplugged but actually to keep it simple, usually there's some electricity hidden in it ready to leap out and shock you to death.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/757098-final-work-about-testing/#findComment-9575256
cd-rom:
broken laser
dusty laser
No power
hdd:
weird noises
random freezes
corrupted files
broken motor
psu:
thanks for this :D
for now in my final work is about 10k words and i am going crazy and nuts :D
do you think this gonna be plenty information to end school?
https://linustechtips.com/topic/757098-final-work-about-testing/#findComment-9575650
On 3/25/2017 at 1:40 PM, Matiasqooo said:
thanks for this :D
Honestly, just a handful of examples of every pc component should do it.
The thing is that you can't document everything.
Sometimes the solution doesn't even make sense for some problems.
https://linustechtips.com/topic/757098-final-work-about-testing/#findComment-9581329
