So I finally could buy the parts that I wanted and I have my PC now running for 6 months and yeah here are some pics:
Front
225c0dbc-9d63-4e53-8f0c-0a3d82b80055.jpg.a259100c95360f5e32af0c120c9a132d.jpgf74babbf-b710-4062-918b-9642c7e87aed.jpg.56b28df4f28a2afc630b6baeb2487dba.jpg
My RIG: With cool GPU arm:ph34r:
33325c25-35dd-4fc5-ae38-05be21b42b76.jpg.c2277356b237d7dfd82e0a2fa1fb6290.jpg067e6fe4-e74e-4cbc-9a90-e0a797957264.jpg.1e169452733ec5265c9c155a10a80991.jpg7d258675-905f-45e9-aa02-3a63baaa9c81.thumb.jpg.328abdcf23897fd2aca3009655154d62.jpg
Cable management
Realbench and System:
After Benchmark
What do you think?
(Sorry that it is dusty :P)
Later I want to upgrade to an Asus 1080 ti and maybe a EKWB Watercooling.
Main Rig:
| Asus Maxmimus VIII HERO | 6700k @ 4.8GHz | 16GB Corsair LED @2666MHz | Asus ROG 1070 @ 20xxMHz , 9200MHz | Corsair Hydro H100i v2 | Corsair 780T | Samsung850 EVO 500GB | 1 TB & 2TB Seagate HDD | DVD Drive :ph34r:| PS4 Controller | Superflower LEADEX 750 W 80+G | Noctua & Corsair Fans |
Peripherie:
| Corsair K70 LUX | Asus GX1000 | Rode NT USB | PS4 | Sennheiser 185 Headphones | Corsair Void Headset | ASus PG279Q & Sony 4k TV |  Lamp | Mousepad |
https://linustechtips.com/topic/756944-my-first-own-built-rig/
6 minutes ago, TheEpicDuck said:
Get rid of that fan in the bottom. even tough you have a dust filter it will suck in a lot of dust. otherwise it looks good
But isn't it good for cooling the VGA?
Main Rig:
Peripherie:
https://linustechtips.com/topic/756944-my-first-own-built-rig/#findComment-9570330
Lawl. No need to get rid of the bottom fan. Dust doesn't work in the way that it only collects through the bottom. Dust isn't prejudice.  Dust is in the air and will go through any fan; Bottom, Front, Back, Side, top, It doesn't matter nor does it care.
That Noctua fan is the only decent fan you have in that whole case OP, it doesn't make sense to get rid of it. Either way nice build and good job.
I7-7700k@5.1ghz + 1080ti @ 2050mhz + 32gbs Ram + 2TB SSD = CSGO
i7-6700k@4.9ghz + 980ti @ 1501mhz + 16gbs Ram + 1 TB SSD = Backup
i7-3770k@4.8ghz + 680 4gb + 32gbs Ram + 500gb SSD = Retired/Office work
https://linustechtips.com/topic/756944-my-first-own-built-rig/#findComment-9575461
  • 1 month later...
There is more dust on the floor than in the air. rly late response
https://linustechtips.com/topic/756944-my-first-own-built-rig/#findComment-9740211
*facepalm* - ya know, I can be dumb sometimes, but wow. That's a new level right there buddy.
I posted a day after the OP, you necro the thread 30 days later. gj
Dust is in the air, it settles on the floor. Next sunny day open the curtains, find a sun beam, and have a look at all the dust. If you still are unable to understand that dust will go through any fan slot top, side, or bottom; then I can not help you.
Good day.
https://linustechtips.com/topic/756944-my-first-own-built-rig/#findComment-9740405
Good day.
Next level of stupidity right here. Do you vacuum your air? Fan on the bottom will let more dust into the case. By pulling it in from the floor.
https://linustechtips.com/topic/756944-my-first-own-built-rig/#findComment-9744560
