Trying to figure out how to fit a CPU watercooler, preferably H100i or something similar into my NZXT Phantom Full Tower case. I have 2, 200mm fans in the top already and really don't want to remove them. Any suggestions?
as far as i have seen the top is the only place to fit an h100i or similar cooler in that case unless you have a really short gpu then you might be able to mount it onto your drive cages but i would check clearances on that first
https://linustechtips.com/topic/75691-nzxt-cpu-watercooling/#findComment-1037248
