Should I go with a Midtower build or a itx build ?
Victor F.
My hobbies include: machining, electronics, radiation, and guns
DESKTOP: CPU: Ryzen 5 3600  Motherboard: Asus ROG B550-I RAM: Corsair Vegenence DDR4-3000 SSD: Samsung 970 Pro GPU: MSI GTX1070 Ti Titanium CASE: NZXT H1
LAPTOP: Apple MacBook Pro i7, 16gb ram, 256gb ssd. (2018 model)
CAMERA: Panasonic Lumix G85
PHONE: iPhone 7
DRONE: Dji Mavic Pro
https://linustechtips.com/topic/756782-midtower-or-itx-build/
I love itx system, The cases yuo get for them are super varied. My Mrs last system I built in a 250D and would love to do another one !
Just find unless you SLI/XFire the case just looks empty, I get that every time I look into mine.
If you WCooling Itx is also epic, but if its your first loop might be worth going mid tower.
What parts/ cases you looking at ?
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
https://linustechtips.com/topic/756782-midtower-or-itx-build/#findComment-9568488
Did you see the error on your itx build?
Quote
Unable to verify the Phanteks Enthoo EVOLV ITX Mini ITX Tower Case has sufficient mounting depth to support the Corsair H100i v2 70.7 CFM Liquid CPU Cooler 240mm radiator.
Perhaps you should verify if it fits.
https://linustechtips.com/topic/756782-midtower-or-itx-build/#findComment-9568489
To be fair the case you picked isn't really much smaller than a more compact mid tower...
I'd also make some tweaks and throw a 1080Ti in there.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/756782-midtower-or-itx-build/#findComment-9568494
It does, I looked on the build guides. People have done it before.
Victor F.
PHONE: iPhone 7
https://linustechtips.com/topic/756782-midtower-or-itx-build/#findComment-9568495
2 minutes ago, Daniel Z. said:
Midtower advantages
larger build space
more airflow
easier to build in
you can put more than one GPU or PCIe card
more MOBO choices
more space for custom loops
ITX advantages
smaller form factor
can look really cool if done correctly
Okay, I just cant decide whether to go for a NZXT S340 elite or a PHANTEKS Evolv ITX case. I am leaning more towards the ITX build though.
Victor F.
PHONE: iPhone 7
https://linustechtips.com/topic/756782-midtower-or-itx-build/#findComment-9568507
the s340 is fairly small for a midtower, not good for large GPUs or loops. I haven't had any experience with the phanteks
https://linustechtips.com/topic/756782-midtower-or-itx-build/#findComment-9568515
I'm not going to be doing any custom loops and if I was I probably would get a Corsair C70 vengeance case. The S340 is small and that's what I like about it. Another case that I saw that I like was the Evga DB87
Victor F.
PHONE: iPhone 7
https://linustechtips.com/topic/756782-midtower-or-itx-build/#findComment-9568534
yes then s340 1337 gets my vote
https://linustechtips.com/topic/756782-midtower-or-itx-build/#findComment-9568538
2 minutes ago, anticeon said:
I prefer Small built but make sure the case long enough for GPU
It is
Victor F.
PHONE: iPhone 7
https://linustechtips.com/topic/756782-midtower-or-itx-build/#findComment-9568572
