Just got a loop all put together. The pump I'm using is the EK-XRES 100 Revo D5 PWM.
Its not running consistently or constantly. It ramps up and shuts off, ramps up and shuts off. I've gotten it to run correct a couple times when restarting the computer. But stops working correct once windows loads in fully.
So it seems I can get a signal to it. But something is preventing it or something weird is going on. Anyone have any ideas?
Using it with a Maximum Code and a 7700k
https://linustechtips.com/topic/756777-pump-not-working-right/
RMA.
CPU: I7 8700k @ 5ghz | Motherboard: Asus Z370-Prime | RAM: White Crucial balistix DDR4 2133mhz | GPU: GTX 1080TI | Storage: ssd HyperX 240gig, 2x2tb seagate Firecuda 1tb, BPX 480 gig nvme, 1tb sandisk ssd  | Cooling: Custom loop | PSU: Evga supernova 850w G2 | Case: Phanteks enthoo evolv atx black White modded | system theme: White/RGB/Weiss
https://linustechtips.com/topic/756777-pump-not-working-right/#findComment-9568394
test mobo with a fan see if it exhibits similar problems.
but its probs the pump
https://linustechtips.com/topic/756777-pump-not-working-right/#findComment-9568403
1 minute ago, thorbrantly101 said:
RMA.
erm no lol
Did you set up a profile for it in the bios, much like you would a fan? The PWM plug is gonna be connected to a header on the board which uses a temp as dictated in settings to control the fan/pump speed. Normally the CPU. You need to go in and alter the fan/pump profile in q-fan or whatever it is called in your bios to set a temp vs speed gradient. You will find that the gradient is probably too low  at the CPU's idle temps and therefore the pump won't run, just need to up the minimum speed
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/756777-pump-not-working-right/#findComment-9568409
4 minutes ago, stealth80 said:
erm no lol
Yeah. Did that. I should just be able to use the water pump fan header which is set at 100%. Neither works.
https://linustechtips.com/topic/756777-pump-not-working-right/#findComment-9568434
Sounds like a setting aint right, the fact it works until it boots into windows says this to me
My pump and fans load up at full speed until windows starts loading up, then they drop down to the fan curve
try a different header or double/triple check the bios settings for that header - its getting the signal to flash up.
Ryzen Ram Guide
https://linustechtips.com/topic/756777-pump-not-working-right/#findComment-9568463
As a side not, I originally ran 2x 3.2 DDC PWM Ex-res in my old rig and one of the them had issues when it arrived and it was due to the pump housing being too tight, took like 1/4 turn off 2 or 3 of the hex-bolts and it's still working flawlessly now
Ryzen Ram Guide
https://linustechtips.com/topic/756777-pump-not-working-right/#findComment-9568473
