Cpu upgrade advice
Go to solution Solved by RollinLower,
if you want to stay low budget the I7 2600 should fit your needs nicely. still a capable chip for 1080P gaming!
also, this way you won't need a new mobo or RAM, and you can spend the cash you saved on a better GPU, like a 480.
Hi so I am looking to upgrade my cpu I currently have a i3 2120 running on a h61 motherboard can anybody suggest a cpu upgrade that will allow me to play games at 720p to 1080p the gpu will be a rx 460 or a gtx 960 not sure yet,  also must be available second hand in the UK not looking to spend silly amounts of money.
https://linustechtips.com/topic/756630-cpu-upgrade-advice/
See if you can get a used R9 380 instead of a 960. That said...
Pretty much any modern Intel CPU will be an upgrade. An i5 7500 should work alright.
https://linustechtips.com/topic/756630-cpu-upgrade-advice/#findComment-9566439
https://linustechtips.com/topic/756630-cpu-upgrade-advice/#findComment-9566447
I recommend getting a new motherboard first. The H61 series of things is very outdated. A H170 board would be a good choice. If you do decide upon getting a board like that, an i5 6500 or i7 6700 would be a great choice.
CPU: Intel Core i7 8700
GPU: Gigabyte GeForce GTX 1070
MOBO: ASUS Z370-F STRIX
RAM: 16GB Corsair Vengeance DDR4 2133MHz
https://linustechtips.com/topic/756630-cpu-upgrade-advice/#findComment-9566457
That's no longer an upgrade at that point, that's an entire platform change. Not only does that require a new board and CPU, but new DDR4 modules as well.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/756630-cpu-upgrade-advice/#findComment-9566532
