I recently received a h55 mobo with a i3 540 I went to see if it boots and it booted linux mint fine. When i tried to boot windows 10 it wouldn't boot it would freze i tried this on 2 ssd's and a hdd  i also tried these drives on a different machine. I then thought it had to do with the mobo not supporting win 10 so i tried win 7 put that on a ssd and hdd they both boot but it freezez like win 10 on the loading screen any ideas
https://linustechtips.com/topic/756407-mobo-issues/
It's because you're trying to boot an installation of Windows that was made using another system. This rarely works. You'll have to do a clean install of Windows. Linux isn't as picky, that's why you can literally hand out HDDs with Linux images and they'll boot fine on any supported machine.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/756407-mobo-issues/#findComment-9564117
when i boot a usb from the machine it freezez
https://linustechtips.com/topic/756407-mobo-issues/#findComment-9564158
Are you booting a Windows installation USB?
https://linustechtips.com/topic/756407-mobo-issues/#findComment-9564161
