Just now, Z3N-IS-D3D said:
Hi guys first time poster here, I've got a 980ti and I5 4690K with 8gb of ram. Do I need to upgrade my cpu? Cause I've been getting a lot of FPS drops in games
look on task manger and see if your CPU is maxing out
also what you running the i5 at and what games ?
https://linustechtips.com/topic/755483-need-some-help/#findComment-9553592
no, you need 16GB of RAM for newer titles.
Also, overclock the CPU if you can, if you have good cooling.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/755483-need-some-help/#findComment-9553618
1 minute ago, Z3N-IS-D3D said:
Okay so I need to get another 8gb then for newer titles
...and a CPU cooler if you don't have one already so that you can crank your CPU to 4.2ghz+
https://linustechtips.com/topic/755483-need-some-help/#findComment-9553622
