Ok so I am using a MSI GT730 2GBDDR5 I dont know what the issue is but my OS (win10) will boot up to the main page (My home Screen) then go black and not display anything I know it is not the monitor because I am using it off my laptop with the same VGA cable and everything is it a driver issue or a hardware issue I bought the card just after Christmas this year from Newegg anything would help I dont want to bring it in and pay $50 for a repair at my local PC repair store.
https://linustechtips.com/topic/755237-need-help-with-my-gpu/
Reinstall windows?
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/755237-need-help-with-my-gpu/#findComment-9550505
37 minutes ago, Verrierr said:
Trying booting in safe mode. If it works then it's probably driver issue.
Ok will try that
46 minutes ago, PCGuy_5960 said:
Reinstall windows?
I bought my PC as a rebuilt referb PC I dont have the windows cd or key to re-install it
https://linustechtips.com/topic/755237-need-help-with-my-gpu/#findComment-9550800
Use the Windows Media Creation tool to make a bootable USB flash drive with Windows...
https://linustechtips.com/topic/755237-need-help-with-my-gpu/#findComment-9550807
5 minutes ago, AmdIsBetterThenIntel/Blue said:
I cant get on the PC to do so..it goes black and wont work
Don't you have access to another PC?
https://linustechtips.com/topic/755237-need-help-with-my-gpu/#findComment-9550853
