Get a Rx 480
My system:
CPU: i5-6600K <> Mobo: Gigabyte Z270X Ultra Gaming <> Cooling: Noctua NH-D15 <> GPU: Gigabyte GTX 1070 G1 <> SSD: Intel 600p 256Gb
RAM: Corsair Vengeance LPX (16Gb @ 3000Mhz) <> PSU: Seasonic M12II EVO 620W <> Case: Corsair Carbide 400C <> Fans: 6x Bitfenix Spectre
  Monitor: Asus VG248QE <> Mouse: Steelseries Rival 300 <> Keyboard: Gamdias Hermes Ultimate <> Speakers: Logitech Z333
Ok, my cheapo Bitfenix fans are 120mm, all six of them. Are you happy now?
I am not actually Linus...
You can leave my signature now.....
https://linustechtips.com/topic/754949-best-gpu-for-my-system/#findComment-9547529
14 minutes ago, Mattlinic said:
hey i got a AMD 8370 with a 550W power supply and just wondering whats the best GPU i could get without bottleneck, really interested in a 1060
Budget? If your budget is high enough, you could go with a 1070.
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
https://linustechtips.com/topic/754949-best-gpu-for-my-system/#findComment-9547538
the chokeing would be pretty freaking insaine with a 1070, unless overclocked that CPU can bottleneck a 970(possiably not in titles that can use all the cores though). i would get a RX 480 or RX 470 depending on your budget and then get a nice CPU cooler and overclock that chip past 4GHz
Builds:
https://linustechtips.com/topic/754949-best-gpu-for-my-system/#findComment-9547550
That 1070 won't bottleneck the 8370 at all. And also you'll get some nice FPS.
TO BE UPGRADED:
https://linustechtips.com/topic/754949-best-gpu-for-my-system/#findComment-9547569
no, the 8370 will choke, not the 1070. there is no way that the 8370 is going to handle that amount of GPU seeing as a I5 7600k will even bottleneck the 1070 at stock
Builds:
https://linustechtips.com/topic/754949-best-gpu-for-my-system/#findComment-9547574
this. 1070 is a beast, why restrict it with am3+ garbage from 2012
idk
https://linustechtips.com/topic/754949-best-gpu-for-my-system/#findComment-9547580
sir ur wrong. my 8350 @ 5ghz bottlenecked a stock 980 in many games
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/754949-best-gpu-for-my-system/#findComment-9547581
Cuz I got a 960 right now and had issues with frame dropping on rainbow six and also screen tearing which hasent happend in a while mind u.. prolly cuz they optimized the game or new drivers I dunno either way I can't run full settings in a game without frame drops
https://linustechtips.com/topic/754949-best-gpu-for-my-system/#findComment-9549005
so the general consensus is 1070 will be bottlenecked but some were saying a a 980 can be bottlenecked which leaves me wondering if i should even get a graphics card a tall cuz i have a 960, i guess i would need to see some benchmarks or somthing for proof
https://linustechtips.com/topic/754949-best-gpu-for-my-system/#findComment-9549106
