I have a Lenovo Z70 laptop, i7-5500u, 8gbs DDR3, 1TB HDD and 8GB SSD. I have this laptop on windows 10, will all of its updates. Bluetooth doesnt show up in device manager, or in the settings -> devices. I somehow broke all 3 USB ports, so my USB mouse didnt work anymore. I bought a bluetooth mouse off eBay, and I cant find ANY settings on bluetooth, or ANYTHING about bluetooth on my laptop. Can anyone help me? I hate touchpads
https://linustechtips.com/topic/754377-help-bluetooth-issue/
This is not a networking issue. I would recommend posting in the troubleshooting section in the future.
My native language is C++
https://linustechtips.com/topic/754377-help-bluetooth-issue/#findComment-9541831
Try downloading the Lenovo Utility
http://pcsupport.lenovo.com/us/en/products/LAPTOPS-AND-NETBOOKS/LENOVO-Z-SERIES-LAPTOPS/Z70-80/downloads
also bluetooth drivers
http://support.lenovo.com/us/en/downloads/ds101755
https://linustechtips.com/topic/754377-help-bluetooth-issue/#findComment-9541908
The bluetooth one is for windows 8.1 im on 10. I did a driver update from the first link for bluetooth, and it gave me the error
run in compatibility mode. admin mode.
this fix is from lenovo support
I had this exact problem today after a windows 10 update ran last night.  I shutdown, started the bios config with the novo button, turned off wireless, saved and booted, then Bluetooth was back! So shutdown again, started bios config, enabled wireless, saved and rebooted.  I saw this fix mentioned on another site, so thought I would post my solution here in case it helps someone else.
https://linustechtips.com/topic/754377-help-bluetooth-issue/#findComment-9542003
I honestly dont want to try that. The driver file still didnt work in "start in admin".
https://linustechtips.com/topic/754377-help-bluetooth-issue/#findComment-9542065
