Need help with choosing a sub for new speakers
Solved by SSL,
My preference would be for SVS SB-1000. Sealed 12", ought to play nicely with the T1s and digs below 30Hz, which is what separates a $500 sub from stuff in the $300 range. None of the subs you're considering go quite as low.
My next choice from your list is the Sunfire. It is also sealed and the dual-driver design is interesting to me. Finally, the Martin Logan, which is a well-regarded brand.
I'm giving preference to sealed subs (e.g. don't have a bass reflex port) since these are generally quicker and cleaner than budget ported subs, and thus better for music. The T1s are also sealed, so it would be a shame to pair them with a cheapo ported sub.
