Problem with RAID Controller
Solved by scottyseng,
5 hours ago, Farmer93 said:-snip-
https://www.broadcom.com/products/storage/host-bus-adapters/sas-9300-8i
This is a good new HBA card to use. Just note that this card uses SAS 3 (12Gb/s) ports. The SAS 2 (6Gb/s) ports you see on some older equipment uses different ports. Make sure you get the right cables as needed.
I think you might've run into RAID cards that can be converted to HBA cards. Not many RAID cards do this (Most don't). It usually involves flashing the card with HBA firmware / turning a setting on / off in the card BIOS.
But yeah, I would really recommend a HBA card for FreeNAS so it has direct access to the drives and let ZFS handle the arrays. It does what it does best with direct access.
