he is wanting to spend as little as possibale so i have found this http://prntscr.com/23maqu he has a budget of £450 i know the one above is £455 but he needs a monitor and a keyboard as well as a mouse i found the one above but am wondering if anyone else has any suggestions for a cheaper or better build.
main rig: http://uk.pcpartpicker.com/p/GFvH7P
next upgrades. h440 . 8320.  possible liquid cooling AIO
https://linustechtips.com/topic/75243-build-for-a-friend/
What's the system being used for?
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1030992
Looks like a really nice cheap build but I'm sure someone will suggest an AMD APU system ... :)
he wants to have the upgradeability without having to but a full new pc
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1030999
he wants to get into pc gaming
How's this look? http://uk.pcpartpicker.com/p/218Tr
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031005
looks good but how would he be able to upgrade that with just a better psu and gpu as that cpu looks good
ohh he needs ram or should i as that 4 gb from novatech?
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031016
There's a UK part PICKER D: Praise_c8b048_1529357.jpg
Are there other countries as well like Switzerland :D ??!! O.o
thought  you knew man don't know about switzerland just google it
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031023
I think I did know about it, but I had completely forgotten about it xD
Re-discovery is awesome :D
But nah I think it's only UK and USA :)
PROFILEYEAH
What do people even put in these things?
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031032
Oh boy, I forgot the ram ._.
http://uk.pcpartpicker.com/p/2194a
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031033
there is a drop down box to select your country on the top right hand corner of the page in pcpartpicker...
since he wants upgradability I'd say he should rather go with a single 4 gig and just buy another later.
ok thanks i will point him towards this one.
just quoting to notify.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031126
I agree. Budget's just a bit tight. Doable though.
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031129
thanks for the heads up i will get looking
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031149
Yea, well a few extra bucks now and he'll remain in the budget and save himself from having to sit with 2x useless pieces of ram once he feels the urge to upgrade to 8 gb so yea, he really ought to cough up the little bit extra.
SWEET xD D:
haha yea.
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031155
right found this http://uk.pcpartpicker.com/part/a-data-memory-ad3u1333c4g9r and it's still in budget he does not need the frequency as he is not gonna be using on board graphics so what do you guys think?
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031163
It's good enough, but if you can find some kingstons for cheaper, my 1333s OC to 1600 like it was nothing, keeping the latency the same as well. I'd recommend this, it's cheaper. http://uk.pcpartpicker.com/part/kingston-memory-khx16c9b1r4
or http://uk.pcpartpicker.com/part/kingston-memory-khx13c9b1r4
Edit: The reason I don't recommend going for Adata memory is because they push them to the max from factory settings so they have little headroom for overclocks while kingston leaves headroom to go up at least one notch. (1333MHz Kingstons are actually underclocked 1600s if that explains it better)
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031178
thanks i will get them for him and whn i feel i need more i know where to look thanks again
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031213
no probs. Hope he likes the world of pc gaming  :D
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031217
haha yea.
Everything around Switzerland, but not Switzerland :(
oh well :D
I've always got http://www.toppreise.ch xD
Just nice to have it all laid out like Part Picker Top Preise doesn't do that just price comparison :)
PROFILEYEAH
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031257
In my  opium the fm2 motherboards and cpu/gpu is suppose to use them so you don't need to use a dedicated graphics card but still be able to fit into a lower budget but still have the upgradability of your system   and at the budget that your friend has the amd apu build is ideal for now  My suggestion is
http://uk.pcpartpicker.com/p/21aby
https://linustechtips.com/topic/75243-build-for-a-friend/#findComment-1031416
