Hi everyone,
I am planning om making my game pc watercooled. But I am not sure which components to buy. So which components do I need? And can someone show me the best components and a cheap but reliable parts?
I will prefer glass tubing. Not rubber or plastic.
My build is the RAZER theme build in my description. The cpu will be upgraded to i7 7700K.
Thanks!
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/751567-help-with-watercooling/
Unless you want to make a custom loop, which I would not recommend, just buy an AIO. Corsair makes a bunch of them.
http://www.corsair.com/en-us/cooling
NZXT makes some
https://www.nzxt.com/product-overview/kraken
and there are a bunch of others available too.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/751567-help-with-watercooling/#findComment-9510657
9 minutes ago, Walt said:
Hi everyone,
Thanks!
This is a good place to start but in terms of glass tubing with no bends that can dramatically increase the cost due to the fittings, as of currently I think only Alpahcool is the only one offering glass tubing:
https://www.ekwb.com/custom-loop-configurator/
http://www.performance-pcs.com/alphacool-hardtube-16-11mm-borosilicate-glass-40cm.html
https://linustechtips.com/topic/751567-help-with-watercooling/#findComment-9510661
