I want to upgrade my old i5-750, but I have a few questions. My budget is $180 in cash and an extra $140-ish dollars on Amazon.ca. My question is, what should I upgrade to? I'm staying with mITX, and I'm nervous about overclocking, but am willing to do it if it is good value. I'm in London, Ontario. Thanks for the help!
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/751475-another-upgrade-post-sigh/
All of my estimates are based on CAD since you're Canadian.
$180 CAD is quite a grey area. I think G4560 is the answer - you can get it at $79 ( http://www.ncix.com/detail/intel-pentium-processor-g4560-2core-de-138312.htm?affiliateid=7474144 ).
$140 would go for mobo, and you can get this ( https://www.amazon.ca/ASRock-Motherboard-Mini-H110M-ITX-AC/dp/B01AVPBOFI/ ) at $110.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
10 hours ago, LeapFrogMasterRace said:
You might be able to get a modern i3, new mITX and some DDR4 for around that but it sounds like you need a whole new system, if this is for modern gaming I would just get a RX 480 or something now and upgrade the rest later.
The RX 470 I currently have does everything I need it to, but I play games like BeamNG.drive, which is a pretty CPU intensive game. When I start spawning and crashing multiple cars, it starts to lag.
10 hours ago, GDRRiley said:
Is the Pentium really worth the upgrade? Are there any benchmarks? Like I said before, I play BeamNG,drive and Team Fortress 2 a lot if that helps.
SPECS:
@PenPoint @GDRRiley @LeapFrogMasterRace If it's a good deal, I found an i5-2500k on CeX for $70. I could buy it online and get it shipped to Canada (would that work?)
https://us.webuy.com/product.php?sku=SCPUINTI52500KA#.WMXl1zsrI2w
SPECS:
NOPE. G4560 is a better idea in every single perspective: and in case of the performance, those two will be similar because they have a quite big gap in terms of generation.
I just surfed Canadian pcpartpicker again and i3-7100 will best fit your budget: $150. 7100 will easily beat 2500K.
Are you sure that the i3 will beat out the i5? I found some benchmarks which don't support that claim, especially with the price gap between the 2.
http://cpu.userbenchmark.com/Compare/Intel-Core-i5-2500K-vs-Intel-Core-i3-7100/619vs3891
SPECS:
Considering 7100 is at least slightly better than 6100 by its higher clock speed(approx 5.5%), it seems like those two are tie.
