Need some tips on first build
Go to solution Solved by WoodenMarker,
Eww, red ram and a blue mobo.
Edits: http://ca.pcpartpicker.com/p/219iY
Building my first gaming rig, planning to spend $1000 CAD - $1500 CAD ( no peripherals or monitors)
PCPartPicker part list: http://ca.pcpartpicker.com/p/1Xdsj
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($343.82 @ Amazon Canada)
CPU Cooler: Corsair H60 74.4 CFM Liquid CPU Cooler  ($72.78 @ Newegg Canada)
Motherboard: Gigabyte GA-Z87X-UD3H ATX LGA1150 Motherboard  ($183.12 @ Vuugo)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory  ($84.37 @ Newegg Canada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($72.52 @ Vuugo)
Video Card: Asus Radeon R9 280X 3GB Video Card  ($377.62 @ Newegg Canada)
Case: NZXT Phantom 410 (Gunmetal/Black) ATX Mid Tower Case  ($119.84 @ Amazon Canada)
Power Supply: Corsair CX 600W 80 PLUS Bronze Certified ATX12V Power Supply  ($61.58 @ Canada Computers)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($22.38 @ Canada Computers)
Operating System: Microsoft Windows 8.1 - OEM (64-bit)  ($100.56 @ DirectCanada)
Total: $1438.59
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-11-11 22:29 EST-0500)
-  should i change anything? planning on changing stock fans in the future and might do some light editing with this rig
https://linustechtips.com/topic/75147-need-some-tips-on-first-build/
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($237.99 @ NCIX)
CPU Cooler:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.79 @ DirectCanada)
Motherboard:  Gigabyte GA-Z87X-UD4H ATX LGA1150 Motherboard  ($183.50 @ Vuugo)
Memory:  GeIL EVO Veloce Series 8GB (2 x 4GB) DDR3-1600 Memory  ($71.99 @ Newegg Canada)
Storage:  Samsung 840 EVO 120GB 2.5" Solid State Disk  ($99.79 @ DirectCanada)
Storage:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($64.75 @ Vuugo)
Video Card:  Galaxy GeForce GTX 780 3GB Video Card  ($499.99 @ NCIX)
Case:  NZXT Phantom 410 (Gunmetal/Black) ATX Mid Tower Case  ($107.00 @ Amazon Canada)
Power Supply:  Corsair CX 600W 80 PLUS Bronze Certified ATX12V Power Supply  ($54.99 @ Canada Computers)
Optical Drive:  Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.99 @ Canada Computers)
Operating System:  Microsoft Windows 8.1 - OEM (64-bit)  ($89.79 @ DirectCanada)
Total: $1458.57
(Generated by PCPartPicker 2013-11-11 22:39 EST-0500)
This will be much better for gaming.
Would either get a 4770k or dump the Z87 motherboard.
Would also go with a Hyper 212 Evo over the H60. Cheaper, Equivalent performance, No risk of leaking, and No risk of pump dying.
4770k is pretty pointless for a gaming build?
Motherboard:  MSI Z87-GD65 Gaming ATX LGA1150 Motherboard  ($188.50 @ Vuugo)
Memory:  Kingston Black Series 8GB (2 x 4GB) DDR3-1600 Memory  ($80.98 @ Newegg Canada)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($61.98 @ Newegg Canada)
Video Card:  MSI GeForce GTX 780 3GB Video Card  ($539.50 @ Vuugo)
Case:  Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case  ($109.99 @ Memory Express)
Optical Drive:  LG GH24NS95 DVD/CD Writer  ($17.00 @ Vuugo)
Total: $1554.19
(Generated by PCPartPicker 2013-11-11 22:43 EST-0500)
My Current Build:
Intel i5 3570K @ 4.4GHz 1.11V, Cooler Master Hyper 212 EVO, Asrock Z77 Extreme4, Corsair Vengeance 8GB 1600MHz, Samsung 840 EVO 250GB, Asus GTX 760 DCII Overclocked, Corsair CX600M
Here are my opinions and suggestions.
1) Why not get a unlocked processor? or go i5 then OC the hell out of it. (If you are just gaming and light editing an i7 is pretty much useless)
2) Swap out the H60 and get a decent Tower Cooler. The H60 is kinda sucky. Get a Noctua NH-D14 or C14.
3) Scrap the Blue drive. Get a black drive (blues are prone to bad sectors that lead to corrupt data)
4) Wait for the 290 with non reference cooler.
CPU: i5 -2400 Cooler: Noctua NH-L12 Mobo: Fatal1ty Z68 Pro Gen3 Memory: Corsair Vengeance 8gb 1600mhz SSD: Samsung 840 120gb HDD: WD 3TB Green, Seagate Barracuda 1TB GPU: Asus GTX 760 Direct CU II (future SLI) Sound card: Xonar Phoebus PSU: Corsair RM series 750 watts Case: Aerocool Mechatron Fans: Bit Fenix Spectre Pros
Monitor:Samsung SyncMaster SA950, Philips Blade 234CLSpeakers: Logitech z506 Headset: Razer Tiamat 7.1 KB: Blackwidow Ultimate Stealth edition Mouse: Ouroburos Mouse pad: Golaithus Extended Speed edition Gamepad: Orbweaver Controllers: Wireless Xbox 360 Controller, Razer Hydra
System: Razer Edge Mouse: Razer Orochi Mouse pad: Razer Vespula Controlers: Razer Sabertooth (2 pcs.) Headset: Razer Blackshark Speakers: Razer Ferox What can I say, I'm a huge fan of Razer.  :D
I agree with the downgrade to the i5. You don't really need an i7 unless you're doing professional work. I'd also say that an SSD is a must have for any new build. The computer wouldn't seem much faster, response, or 'worth it' than an existing computer you might have.
Intel Core i5 2500k @ 4.2GHz | Corsair Vengeance 16GB 1600MHz | MSI GTX660 Twin Frozr II OC | Samsung Evo 850 250GB | Seagate Barracuda 3TB | Corsair 600T White | Corsair H100 | Corsair HX850 | Corsair SP120 QE | Asus MX279H | LG Flatron E2251 | Logitech G502 | Das Keyboard Ultimate 4 Browns | Fiio E10 | Beyerdynamic Custom One Pro | Corsair SP2500 | HTC One M8 | MacBook Air (Mid 2013) i5 8GB 128GB
BF4 benefits more from i7 than previous generations of games. Likely this trend will continue. On the other hand if an SSD isn't included, use the difference between an i5 and i7 to pay for it.
That may be true but if you look at the CPU utilization vs FPS produced. It's still minimal, definitely not enough to justify the cost.
Unless the difference between an i5 and i7 is 15++ frames(in ultra) I wouldn't bother.
It's only one set of benchmarks of one game but the BF4 cpu benchmark graph here shows i5-4670K at 72/95 and i7-4770K at 92/115.
The point I was trying to make was that the conventional wisdom that i7 does not contribute enough to performance to justify the added cost is changing. Real world performance is determined in large part by the gpu solution in the system.  As gpu become even more powerful the difference between i5 and i7 will continue to widen.
So what you are saying is it doesnt' justify the cost right? =))) I kinda just proved my point.
Don't know how you got that out of my post. You suggested that a delta of at least 15 fps was needed before an i7 would become "worth it". I provided a link to a benchmark that showed a delta of 20 fps.
But it's a pointless discussion. The most appropriate cpu depends on the budget.
I simply wanted to point out that new games are bringing about a change. If one is investing in a gaming rig that is to last for some time then I believe an i7 is a better investment than an i5 (budget permitting). This is because as more demanding games emerge one is more likely and can more easily improve the gpu solution.
Don't forget it's not just hyperthreading. The i7 has more cache than the i5.
