Lets say I bought this mixer, which doesn't have a USB connector. How do I setup my a microphone and headphones?
https://linustechtips.com/topic/751424-mixer-without-usb-connection/
Also what you want to use the mixer for, Bit more details on your intended setup so @SSL and I might be able to point you in the right direction :)
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
28 minutes ago, SSL said:
You're going to want a USB mixer if you're using this with a PC.
I have a USB Mixer. 302USB variant It does not have "phantom power", I'm using a power suppler to power my mic.
1 minute ago, SSL said:
Then get the version with phantom power.
Like this?
Premium 5 Input 2 Bus Mixer with XENYX Mic Preamp/Compressor/British EQ and USB/Audio Interface
https://www.amazon.co.uk/Premium-Preamp-Compressor-British-Interface/dp/B008O516JW/ref=sr_1_1?ie=UTF8&qid=1489368511&sr=8-1&keywords=502usb
Just now, Abdul201588 said:
Like this?
Sure. Are you actually using the mixer capabilities, or would a straight interface be a better fit?
I'm using the mixer, I want to start a podcast with my friends, I've got the mic, which is a Neweer NW-700.
Just now, SSL said:
But do you need a mixer or an interface? How are you using the mixer?
I'm using the mixer with the levels. Although the one I've got is limited. Also, I might add another Mic for when someone want's to talk with me.
But if you're only using this for a microphone then you're better off just getting an audio interface.
I've been using a focusrite scarlett 2i2 for years for just voice recording for music project more than happy. You don't really need the levels as you not doing live mixing, You should be fixing audio levels in editing
Redstone:
Obsidian:
