system spec as follows:
Antec GX1200 gaming case,
Asus sabertooth 990fx r2.0
Asus strix R9 390 OC DC3 8GB
AMD 9590FX
Corsair 850 Gold+ PSU
8GB CORSAIR DOMINATOR RAM.
Here is my problem.
I originally had my 9590 aio cooled with the Corsair H80 push pull.
Now my cpu Temps were always high with that cooler and overheating.
I have upgraded to a 240mm AIO push (brand is called Uphere).
that cooled my cpu ok ish, lowered the temps between 5-10c, but now even that cooler doesnt seem enough to cool this bbq of a cpu.
I have had to underclock and under volt it to be able to type this and temps are still stupid high, 54c.
i upgraded the fans to some corsair fans same as the H80 fans and still no difference.
I have hit a wall as to what i can do to cool this thing, my funds have ran dry also so i cant upgrade cooler again.
hell i had to upgrade my case so the cooler will fit lol.
Any help from anyone would be appreciated, im desperate. (im sure i have lost hair because of this).
P.S.  the AIO cooler i have is this: https://www.amazon.co.uk/gp/product/B01I5K0E8O/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Thank you in advance.
David
https://linustechtips.com/topic/751192-fx9590-overheating/
Hey even Linus forgot.
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/751192-fx9590-overheating/#findComment-9507113
Maybe the thermal paste sucks or it some how is not fully pressed to the cpu
https://linustechtips.com/topic/751192-fx9590-overheating/#findComment-9507123
54C under load is fine. However, you ahd to underclock for that, so of course it's not ideal. How much could you undervolt while keeping stock clocks? The FX-9xxx default to more than 1.5v, so they are very hard to keep cool in stress tests and so on, even with 240mm AIOs. However, they may admit lower voltages, although the 9590 probably not much since it's 4.7GHz stock - a rather high overclock.
Check the LLC options of your Sabertooth as well: high LLC will help you eliminate any fluctuations in vcore and give you more control, but it will also make your temps higher.
For reference (in a worse OC board than the Sabertooth), I undervolted a 9370 to 1.385v, and even managed to OC it to 4510 at that voltage (+5MHz stock multipliers). My vcore an drop to ~1.34v in stress test (no LLC here), so with your board you may get it stable at something close to 1.35v. If you manage to pull that out, you will probably be fine with the AIO and just giving up 200MHz. But you didn't get a 9590 to run at 4.5, so it's worth trying voltage settings until you can thermally manage a stable 4.7 ;)
https://linustechtips.com/topic/751192-fx9590-overheating/#findComment-9507288
54c was at idle, ive kept stock clock to try it and volts at 1.39 seems to be stable
https://linustechtips.com/topic/751192-fx9590-overheating/#findComment-9507356
That is strange, it shouldn't get too warm idling if the cooler works normally. Is that socket temp (as measured by the motherboard) or the package temp reported by the CPU? The latter is usually some fake sub-ambient number in idle. Socket temps can be high even if the package temps are low due to VRMs getting hotter. If it's only the socket temp that it's that high, you can try attaching a small fan on the VRM heatsink and see if that improves.
I wouldn't expect more than 30s-40s in idle socket temps, though.
https://linustechtips.com/topic/751192-fx9590-overheating/#findComment-9507371
1 hour ago, Cptdavepilm said:
NOPE, still overheating... this is driving me insane
Do some sanity checks like feeling if the tubes of the AiO are warm to the touch, the waterblock is warm and most importantly check CPU temps immediately after a coldstart when it has been turned off for a couple hours.
What are the load temps at?
\\ QUIET AUDIO WORKSTATION //
5960X 3.7GHz @ 0.983V / ASUS X99-A USB3.1
32 GB G.Skill Ripjaws 4 & 2667MHz @ 1.2V
AMD R9 Fury X
256GB SM961 + 1TB Samsung 850 Evo
Cooler Master Silencio 652S (soon Calyos NSG S0 ^^)
Noctua NH-D15 / 3x NF-S12A
Seasonic PRIME Titanium 750W
Logitech G810 Orion Spectrum / Logitech G900
2x Samsung S24E650BW 16:10  / Adam A7X / Fractal Axe Fx 2 Mark I
Windows 7 Ultimate
4K GAMING/EMULATION RIG
Xeon X5670 4.2Ghz (200BCLK) @ ~1.38V / Asus P6X58D Premium
12GB Corsair Vengeance 1600Mhz
Gainward GTX 1080 Golden Sample
Intel 535 Series 240 GB + San Disk SSD Plus 512GB
Corsair Crystal 570X
Noctua NH-S12
Be Quiet Dark Rock 11 650W
Logitech K830
Xbox One Wireless Controller
Logitech Z623 Speakers/Subwoofer
Windows 10 Pro
https://linustechtips.com/topic/751192-fx9590-overheating/#findComment-9508856
I've had similar questions with my Asus board.  The socket temps are much higher than the core temps.  If you're looking at temp readings from Asus AI Suite, for example, it will show the socket temp.  The socket is not cooled, so it just builds up heat until there's enough to pass through the board/cpu.  My core temps rarely, go over 50c, but my socket temp reading will show 62-63 at idle.  I'm running an 8320, so my numbers will be lower.  Try a different utility to read core temps.  You may find that the core temps are fine.
https://linustechtips.com/topic/751192-fx9590-overheating/#findComment-9511709
Try HWinfo64, I've had zero issues with the Sabertooth though. Either your cooler simply isn't working properly/good enough or you got your voltage on auto and is insane high. This baby idled around 15c-20c (in AMD's weird temp reads) and topped out at 4.7ghz 1.428v ~55c with a NH-D15 so silicon lottery aside you should be around that ?
Ryzen 3800x 4.4ghz 1.294v all core Noctua NH-D15 x570 Aorus Elite 16gb G.Skill Flare X 3600mhz 15-15-15-30 1T
XFX 5700 XT Thicc III Ultra Seasonic Focus+ 650w Platinum
https://linustechtips.com/topic/751192-fx9590-overheating/#findComment-9511998
nope, still overheating. i have fans cooling the socket from the rear, i have fans cooling the VRMs. nothings working. its a shame because it never used to do this, no hardware changes except the cooler to try and remedy this. im thinking maybe my cpu is dying. if it is then i seen ryzen on the horizon (no pun intended).
that being said, this cpu has been really good for me in terms of performance so i will be sad to see it go.
Anyway, thank you for all your help people.
Dave
https://linustechtips.com/topic/751192-fx9590-overheating/#findComment-9518078
  • 10 months later...
i know this is old and this reply is really late, it turned out to be bad thermal paste, i bought from a retailer called maplin and it was old and stored near a shop heater, i replaced it with some MX stuff and it works perfectly now, and stays quite cool :)
thanks to all those who replied
https://linustechtips.com/topic/751192-fx9590-overheating/#findComment-10955102
