The Silverstone ML09 is only 7L and you can fit a 1050 Ti in it. Sure it's not a 1080 Ti but I won't really be comfortable with anything with a higher TDP in something this small anyway plus at 66$ it's an amazing value for those into ultra compact gaming builds and can actually be bought unlike the A4-SFX and the Sentry.
I'd like to see more builds based around this case because to me it's the perfect budget ultra sff case.
https://linustechtips.com/topic/749981-poor-mans-sentrya4-sfx/
I would say something like either the Silverstone SG13 or the Cougar QBX.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/749981-poor-mans-sentrya4-sfx/#findComment-9494186
Yes those cases are way cheaper than the ML09 for sure but the sg13 is 11.5L that's about 40% bigger which is the difference between needing a suitcase vs a backpack for travel. Otherwise I would go for the Enthoo Evolv ITX or the Nano S but those aren't ultra compact at all.
https://linustechtips.com/topic/749981-poor-mans-sentrya4-sfx/#findComment-9494279
