What were you doing? Was it idle? If so you may have a chance but i would say it is dead
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
https://linustechtips.com/topic/749778-cpu-without-a-cooler/#findComment-9491459
Just now, Spenser1337 said:
I turned it on, saw that the mobo worked, turned it off
literally 1 minute
Should be okay but just don't be surprised if it is dead
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
https://linustechtips.com/topic/749778-cpu-without-a-cooler/#findComment-9491484
3 minutes ago, stefanDB said:
the bios isn't very intensive, and the PC should shut down if it gets too hot, but with no cooler at all it may not shut down in time. the best way to find out is to put on a cooler and test it.
Don't have a cooler, planned on using the cooler I had in my dell but I can't get the mounting brackets off of the board
https://linustechtips.com/topic/749778-cpu-without-a-cooler/#findComment-9491572
I've had a 3820 die on me because it didn't turn off when I forgot the thermal paste when it started to boot Windows.
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
https://linustechtips.com/topic/749778-cpu-without-a-cooler/#findComment-9491580
