Razer blade 2017
to the OP - it will handle that fine but probably be too loud for class with a VM running.
I bought the new 7700hq model and have been using it for about 10 days so far, and can attest that it does seem to be much improved from the Skylake versions judging by the negative comments people made about them.
Mine has been fine, but I will admit that curiosity got the best of me so I happily voided the Razer warranty by repasting with Grizzly Kryonaut and replacing the stock thermal pads with Fujipoly extremes to see if I could get the CPU temps even lower (after 2 days of stress testing it was idling in upper 40's C). I also replaced the 256gb PM951 with a 1TB 960 Pro (which generates more heat so I put pads on it too) and swapped the Killer 1525 wifi card for an Intel 8265 for fewer software headaches based on reviews of Killer's software. Also undervolted the CPU by .120mv and igpu by 0.055mv stable.
After all the monkeying around I've done I'd say it's perfect for a mobile workhorse like I wanted. CPU is now idling around 36-40 C in 70 F ambient room, no issues after a week and a half of stress-testing the crap out of it. The fans don't kick on unless CPU cores get above about 65 C or so, which doesn't happen for me doing light stuff like Chrome tabs, Youtube, etc but as I said I am pretty sure that an OS X virtual machine would be strenuous enough to kick them on, and they are not quiet even on the slow speed. You would at best annoy your classmates, and at worst be asked by the professor to turn your machine off.
I can't comment on any previous model because this is my first Razer laptop, but so far overall it seems like decent build quality but I would question the assembly done by hand as the factory paste on the CPU and GPU did not seem to be done well, with some uncomfortably (to me) large spots without any paste on them from the factory, but as I said it was still not overheating even that way. I just improved it with better paste, proper paste method, and better thermal pads.
